Oil leak
Vintage man
Has thanked: 51 times
Been thanked: 7 times
Re: Oil leak
Post by Vintage man »
Thanks, Tony will try that
Vintage man
Re: Oil leak
Not sure what a bulk head fitting is.
The hole is only 6mm and a sharp 90 degree. Do you think bigger diameter and not such a restricted 90 degree could solve the leak
Has thanked: 191 times
Been thanked: 487 times
Re: Oil leak
a bulkhead fitting is a fitting designed to go through a bulkhead or a firewall.
something like
On yours, if keeping the same setup, I'd go up to 3/4" (19mm) for the 90deg and the entry into the filter and then step down to match your current piping which should be around 1/2" or larger
Re: Oil leak
I dont know if the larger fitting will solve your leak, but it will go a good way to preventing it from being bigger than it needs/wants to be.
Vintage man
Re: Oil leak
OK done the bigger connections and will update after next drive.
Thanks guys
Vintage man
Re: Oil leak
Bigger fitting same diameter as pipe and drove.
Fixed no oil pushing out.
Thanks all and ride safe
Re: Oil leak
fantastic news, thanks for letting us know
