Hi,
Can anybody please tell me what is the size of the hole where the threaded part of you crank pulley goes in? Mine is 50,5mm and my threads on the pulley is 50mm. Is this my hole size correct or to big?
It is a 1600 TP
crankshaft pulley hole size
- fourier
- Oil Cooler
- Has thanked: 31 times
- Been thanked: 37 times
Re: crankshaft pulley hole size
Did a quick check on my engine casing. It measures 50.03mm.
At 50.5mm, you will probably end up with a bad oil leak.
(o= i =o) (o\ ! /o)
- Oil Leak
- What model do you have?: 1971 beetle
- Been thanked: 3 times
Thank you Sir ... and that is exactly the problem. The question now is how do fix it? I can't seems to find 50.5 mm Crank pulley
- Has thanked: 191 times
VW did make a bigger pulley for the 0.5mm bigger hole.... you just have to dig through old spares until you find one
- Oil Leak
I have a old aluminium pulley. Will it possible to get it welded up and machined to the correct size?
anything is possible with the right amount of money
I'd rather suggest a sandseal pulley approach - this has a seal which you insert into the case and the pulley has a stainless ring on it to prevent wearing on the seal
and then, who is going to cut the thread correctly????
- fourier
- Oil Cooler
Tony is correct, VW made oversized pulleys (111 105 253B) to solve this problem, but good luck finding one...
Easiest fix, is probability the sand seal route. You may need a custom OD seal holder to fit into the case ID, and a sleeved pulley as Tony suggested. This will be much cheaper than having a custom pulley made, to fit your case.
(o= i =o) (o\ ! /o)
- slak
- Has thanked: 7 times
- Been thanked: 32 times
Best is to get in touch with Bennie(VW Oldies) in Vereeniging and ask him if he might have one for U he has alot of parts
looking for new homes 084 872 eight 7 four 5
U Only Live Once Right !!!
- Oil Leak
Thank you all for the help. I found 0.5mm oversize pulley with the help of the friendly guys at volksieworld. Hope that it will mean the end of my oil leak.
- fourier
- Oil Cooler
Glad you found the correct pulley! Let us know if it solved your problem.
(o= i =o) (o\ ! /o)
