Porsche gauges in Beetle
Posted: Sun Apr 22, 2018 11:28 am
Hi all,
I'm wanting to fit Porsche 924 gauges into my Beetle. I've seen this done by some of the members here & after extensive searching, I have a few technical questions I need help with regarding the combo gauge.
1) Fuel level sender unit, I've read you need the type 3 tube type which reads 10 - 75ohms, but this doesn't support the "low fuel" warning light on the gauge which I'm hoping to keep, Porsche is 3 - 70 ohms. The Porsche sender is also too long to fit the Beetle tank, 300mm as opposed to 170mm. Will the standard lever float level one work using a vibrator on the gauge, I can always fit a thermister to this for the low fuel light warning. A more extreme option was to take a standalone VDO fuel gauge with its sender unit & custom fit this by replacing the original fuel gauge inside the combo gauge. What other options are there?
2) I also want to convert the water temp gauge to a oil temp gauge, the standard Beetle sender which I want to fit in the oil relief plug reads 10 - 180 ohms, the Porsche gauge reads 10 - 300 ohm's. Which sender will give me the most accurate reading?
Any assistance would be greatly appreciated.
