Best jets for 1971 Beetle 1300 Twin port
Oil Seal
Has thanked: 45 times
Been thanked: 40 times
Flag: France
Post by 73type2 » Thu May 17, 2018 11:16 am
What is the best sizes of main and air corrector jets to be used on a 1971 Beetle 1300 twin port at the coast?
Has thanked: 22 times
Been thanked: 143 times
Flag: South Africa
Re: Best jets for 1971 Beetle 1300 Twin port
Post by Dawie » Thu May 17, 2018 12:20 pm
When dual port 1300 was introduced late 1970 (for the 1971 production year), it had unusually big jets, but this was found to be a problem, so VW changed to smaller jetting during the first year.
With it's original German 31PICT carb with 25.5mm venturi, they used 130 mains and 110 air correction.
"Things should be as simple as possible, BUT NO SIMPLER THAN THAT."
"If something can go wrong, it will go wrong" (Murphy's law).
Oil Seal
Flag: France
Post by 73type2 » Thu May 17, 2018 3:14 pm
Thanks Dawie. I'm currently running with a 145 mains and 170 air correction in my Brosol H30/31 carb. I also have a set of 120 mains and 110 air correction. Should I stick these smaller jets in there? I don't have a 130 main jet.
Flag: South Africa
Post by Dawie » Fri May 18, 2018 11:41 am
That 120 main jet is too small for use in combination with the 25.5mm venturi in that carb.
Vw themselves did use smaller jetting in certain applications. Like the USA- version 1600 twinport beetle, which had 127.5 instead of the 130 main used elsewhere.
And the late 1600 bay-kombi, which came with 125 mains instead of the 130 from 1600 beetle versions. But... that 125 jet was used only in combimation with the 90deg elbow, long ducting and side-mounted aircleaner of the kombi.
