CJ vs CU heads
Eugene
Has thanked: 40 times
Been thanked: 46 times
Flag: Croatia
CJ vs CU heads
Post by Eugene » Thu May 17, 2018 4:15 pm
Hey guys, who can show me with pictures aka photos, what the visual differences are between the heads of the two types? The CU, I know has hydraulic lifters but how can you tell when you compare the two?
Has thanked: 87 times
Flag: Bermuda
Re: CJ vs CU heads
Post by Blitzkrieg » Thu May 17, 2018 4:37 pm
CU heads have square exhaust ports
Has thanked: 174 times
Been thanked: 412 times
Flag: Netherlands
Re: CJ vs CU heads
Post by retrovan » Thu May 17, 2018 4:40 pm
The CU has oval ports and the CJ has round ports
Hydraulic lifter you will find in both, and can be fitted to both.
Most guys fit Hydraulic valve lifters to any type 4 as you need not keep setting the valves.
They may be noisy when standing for a wail but lub up after a few kilo's and run silent.
hope it helps
1952 Split Beetle 1835cc (Azure Blue)
1968 Fastback 2Lt.type4( Red)
1972 Low Light Bay Panel Van 2Lt type 4(White)
1975 Fleetline Panel Van 1914cc (Aqua Blue/White)
2019 MeFusco Beetle Truck
Eugene
Flag: Croatia
Re: CJ vs CU heads
Post by Eugene » Thu May 17, 2018 6:38 pm
The CU has oval ports and the CJ has round ports....
This is sort of import important :(
Hey guys, who can show me with pictures aka photos.....
Flag: Netherlands
Re: CJ vs CU heads
Post by retrovan » Thu May 17, 2018 6:50 pm
This is a WBX head, but the ports look something like this
Not easy to find photo of square port but here is a close up
Normally has round ports.
Eugene
Flag: Croatia
Re: CJ vs CU heads
Post by Eugene » Thu May 17, 2018 7:16 pm
Thanks Herman, now, was that so hard? :-)
Flag: Bermuda
Re: CJ vs CU heads
Post by Blitzkrieg » Fri May 18, 2018 8:29 am
The difference in in the EXHAUST ports....Square vs Oval /round not the INLET.
I have square port heads at home that I can take pics of.
Inlet manifolds are mostly interchangeable with the exception if the 3 bolt 914 specific heads.
marcw
What model do you have?: 76 T2 Kombi
Facebook: http://www.facebook.com/marc.wetselaar
Has thanked: 12 times
Been thanked: 6 times
Flag: South Africa
Re: CJ vs CU heads
Post by marcw » Fri May 18, 2018 10:28 am
Square versus Oval from Google
I have both however, changing between them is a costly endeavour having to purchase new exhaust for oval.
Vintage man
Has thanked: 44 times
Flag: South Africa
Re: CJ vs CU heads
Post by Vintage man » Fri May 18, 2018 10:31 am
I have both sets of heads
Has thanked: 25 times
Been thanked: 153 times
Flag: South Africa
Re: CJ vs CU heads
Post by Dawie » Fri May 18, 2018 12:49 pm
In the end, you just need a matched set of heads and heat exchangers.
There is a lot of misleading info on USA websites, as they never had "rest of the world" carbed 2L CJ or CU engines there, only their different smogged fuel injected versions.
Square port heads were introduced - last year of 2L bay production. (1979).
Last year of CJ engine had a special one-year-only heat exchanger. Similar to earlier ones except for the square ends where it meets the heads.
CU-heat exchangers from the square-shape t25/t3 kombi differ by not being fed air from the cooling fan. Instead there is a separate little fan connected to the alternator pulley. So air-ducting of CU heat exchangers are also different from square port CJ/baywindow exchangers and not interchangeable.
By the way only USA code "GE" engines had hydraulic lifters. Introduced there around 1977, so some earlier oval port engines in the USA also had hydraulic lifters. Their earlier solid lifter engines were identified by code "GD". Most of the US 2L engines had totally different "F-shaped" heat exchangers, some combine with catalysts and lambda sensors. Irrelevant to "rest of the world".
CJ- 2L baywindow engines never had hydraulic lifters, even the last square port CJ's were solid lifter. VWSA made a big fuss with the introduction of the newer shape kombi with it's CU engine, saying that for the first time their kombis had hydraulic lifters.
"Things should be as simple as possible, BUT NO SIMPLER THAN THAT."
"If something can go wrong, it will go wrong" (Murphy's law).
Eugene
Flag: Croatia
Re: CJ vs CU heads
Post by Eugene » Fri May 18, 2018 3:52 pm
Thanks for the info so far guys
Ok, so I do know the CJ and CU heads are interchangeable. I am sitting with one each, CJ and CU engine. I am looking to have one rebuilt, using the CJ setup and tinware but the CU heads with hydraulic lifters. I am only looking to strip one motor so wanted to ensure that somebody in the past did not fit manual lifters to a CU engine. As per the attached pics, the only visual difference, without removing exhaust, is the pushrod tube retaining wire.
Here the CJ head with retaining wire
and the CU without
unless you can see some other differences?
sean
Has thanked: 56 times
Been thanked: 188 times
Flag: South Africa
Re: CJ vs CU heads
Post by sean » Fri May 18, 2018 4:31 pm
You will have to remove a lifter to check for sure. You cant assume the CU motor has hydraulic lifters, some one could have changed it. I have found it before. The lifter sits in the block, so doesn't matter what head is fitted to the motor.
Also note if you plan to use those CU heads in a baywindow, the heater boxes are longer if they from a CU microbus engine, so your silencer will not fit and press against the bumper.
I would advise to stick with the CJ heads if its being fitted into a baywindow.
