dog house shroud on a 1500sp
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
Hi All
I have 1500 sp motor that is leaking at the oil cooler, I have a spare dog house shroud with the back plate and was thinking of doing a conversion,
Just need the oil cooler offset thingy, Is this a good idea or should I leave it as it is?
thanks
thanks
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
- Has thanked: 191 times
Re: dog house shroud on a 1500sp
its a good idea
- John Alves
Is the fan size the same for a 1500 and a 1600?
1968 1500 SP Beetle
1968 1500 SP Beetle
- Edmond
- Has thanked: 22 times
- Been thanked: 31 times
Don't forget the conversion oil cooler seals the ones that are 8mm on one side and 10mm on the other. The 1600 TP has a wider fan than the 1500 SP but the diameter is the same
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 321 times
It's a good idea. You will need more than just the doghouse shroud and oil cooler and cooler base. You'll also need the 2 tins that make up the ducting for the warmed air to leave the engine compartment, and also the front (FIF) valence with the slot for the duct to pass through (or you could cut the slot in your existing front (FIF) tin. If you want to get really pedantic, you will also need the "Hoover bit" (google it) that seals the gap between the base of the oil cooler and the shroud.
Twinport engines also use a 35mm deep fan, as opposed to the 33mm fan in single port engines. It's worth buying a new 35mm.
- John Alves
I thought I had all the bits, but unfortunately don't have all the tins, so will be a later project
Thanks for all your help
1968 1500 SP Beetle
1968 1500 SP Beetle
Shelleys will have. they shouldnt cost too much
- John Alves
Didn't realise Shelleys was still around, will go and have a look
1968 1500 SP Beetle
1968 1500 SP Beetle
If you dont know they moved about 5 years ago, look them up to get their new address.
- No More Landy
- Has thanked: 23 times
- Been thanked: 5 times
Shelleys is closed.
Apparently owner got real sick and closed/ sold up.
I was there a few months ago and it's a new business
Sent from my SM-A326B using Tapatalk
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
