Aircooled engine for beetle
sdinath
What model do you have?: Beetle 1600s
Has thanked: 11 times
Been thanked: 4 times
Post by sdinath »
Hi guys,
I'm thinking about changing the engine on my beetle 1600s with a bigger aircooled engine...just for fun :D
I would like to make the car a bit faster.
Any suggestions of which engine to buy? I've seen a beetle with an aircooled porsche engine which enticed me
but I'm not sure how to get one and if it will be feasible.
So I'm willing to consider a bigger vw air cooled engine.
Please let me know what you guys think....
Shaheed
Been thanked: 539 times
Re: Aircooled engine for beetle
Bigger engine will not give you speed by it self,
You would need to either fit bigger wheels or a longer 4th gear or both.
To drive this extra speed you can upgrade the power by either modifying your existing motor , or if your pockets as well everybody in your familys pockets are very deep, you could get a Porsche motor.
Best option is to put bigger barrels and pistons on your engine.
Sure the engine guys will chip in so lets see....
sdinath
Post by sdinath »
Thanks Herman....
I like the idea of modifying the existing engine as my pockets not that deep at the moment.
Shaheed
Has thanked: 191 times
Been thanked: 487 times
Shaheed
The modifications and power limit of the aircooled engine is limited only by your budget and your intended application.
Also, dont be overly quick to build a higher capacity engine, you pay a lot for a very little increase in cc. The 1600 is a good base to start on and once you increase its efficiency, it can really perform.
to wet your pallet - here is a video of my beetle with aircooled beetle engine (highly modified) about a year ago before I broke the gearbox.
sdinath
Post by sdinath »
Wow Tony I'm very impressed :hangloose:
I think you're conversions are on another level.
Thanks for sharing your advise and the video.
Regards
Shaheed
Terry Phillips
Has thanked: 193 times
Been thanked: 121 times
Zambia
Post by Terry Phillips »
Thanks Tony looks like you will have to invite the Dung Beetle over for a run,nice job.
That look on your face tells it all. :D
