Hi, I need some advice please. I have 2 sets of bolts for a wbx flywheel. One is std 20.9 grade cap screws the 2nd is bolts with a marking of b100 (imperial grade I think). Can someone enlighten me on the strength of the b100 bolts? I found on google that it is the hardness of the steel but I have no idea how it compares to 10.9 or 12.9 grade. I went looking for some 12.9 grade cap screws at a bolt and nut shop but they don't stock the threads I need in 12.9.
Bolt grades
- Wentzel
- Has thanked: 6 times
Bolt grades
Oxyboxer Project
Re: Bolt grades
Maybe this will help a bit.
https://www.boltdepot.com/fastener-info ... chart.aspx
Do not know about b100 markings, so can not helpthere.
- Has thanked: 193 times
- Been thanked: 121 times
- Wentzel
Re: Bolt grades
Thank you I will give it a try.
Oxyboxer Project
