Hi Haans
This really isn't necessary on a stock motor. I cant comment on the Ghia setup as I only know busses, but I've never ever overheated a standard aircooled motor, and this is in a bus where the engine labours much more than in a Ghia. If everything is the way it should be, you can drive it hard all day long with no issues. I have a oil temp gauge in 2 busses and its a waste. You don't need any gauges.
This last trip to the George show I was using a bus with a single port motor and old style steel oil cooler that supposedly blocks off cylinders. We drove in 40 degree weather and I was being silly the whole way overtaking other busses, accelerating, decelerating and climbing passes and not even then does the motor get hot.
Oh wait, I forgot, I did once overheat a motor, twice actually, but it was a modified 1700 type 1, then a 1835 which also did it again. Never ever again will I get burnt with modified crap. Standard motors cant overheat.
Universal fan mounting kit ??
- Camshaft
- Been thanked: 107 times
Re: Universal fan mounting kit ??
Sean,..duly noted!
I've acquired all these goodies,..as said younever know what will happen in future.
I will keep all posted with results once rolling.
Regards Haans
Regards Haans
- Camshaft
The first CAD (cardboard aided design) proto to bbe fitted,....space is tight,....so ! When Escom decided that we can have light !! I will be in there to see how it can be fitted.
Lets see where it ends up ?
someone has been watching Project Binki
Looking good there Haans
looks like it will fit.
- Camshaft
Don't hold your breath !,
Blood flowed ! Purple bruises !,......and the muffled language !!!!very bad !
Afew small adjustments on monday,........then back in!
Who's binki ?
Who's binki ?
At least the family has not given you a "Swear Jar" ...
Mine became too small very quickly .....
And here is Binki ...
https://www.youtube.com/watch?v=7hCPODj ... g1qjtxA_nq
Binki is definitely worth a watch... they do a lot of CAD design too
