What am I doing wrong
- Has thanked: 51 times
- Been thanked: 7 times
If I arry out the ignition timing using a test light method and I'm at number 1 rotate the dissy till light comes on it doesn't start as I still have to turn the dissy anti clock wise to start.
- Has thanked: 191 times
Re: What am I doing wrong
turn the engine to tdc #1
take off the dizzy cap
check that the rotor is in fact pointing to the wire for #1 cylinder
if in doubt, start from point zero and work from there.
put engine at TDC #1
take off dizzy cap
turn dizzy so thin "slit" in dizzy lines up with same width mark in rotor.
Put cap back on and put #1 lead onto the cap plug that the rotor is now lined up with.
remove cap again
turn engine clockwise a little, check which way rotor turns
put plug lead for #4 onto next plug point that the rotor will reach, then in same direction, put on #3 lead, then last, #2 lead.
Car should now start without issue.
with a timing light, advance idle timing to 5 or 7.5 deb BTDC
take off dizzy cap
remove cap again
