Getting seized caliper pistons out
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Post by Donovan D »
How can I get these pistons out. Managed to get three out using the compressor but the rest will not move, its proper stuck.
John Alves
Has thanked: 3 times
Been thanked: 48 times
Re: Getting seized caliper pistons out
Post by John Alves »
have you tried some heat?
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
Been thanked: 539 times
connect them to Master cylinder and press them out with brake fluid.
If double sided, then place wood in between so they both move but stop before coming out all together.
Once both have moved, the remove wood and press both out.
