Beetle dog box size
Posted: Fri Mar 27, 2020 7:56 am
by Edmond
Has anyone got the size of the bottom area of the dog box /rear luggage area in a beetle I want to draw up a shallow subwoofer box while I'm on lockdown since i cant work on the baja because it's at my moms house or does anyone have a drawing or spec for a shallow depth sub box
Re: Beetle dog box size
Posted: Fri Mar 27, 2020 12:13 pm
by John Alves
920mm at rear
960mm ar front
390 between
remember that this measured at the bottom so the 390 will decrease as you move up as the rear seat is at an angle
Posted: Fri Mar 27, 2020 4:35 pm
by Edmond
John Alves wrote: Fri Mar 27, 2020 12:13 pm 920mm at rear
960mm ar front
390 between
Thanks John
Posted: Sat Mar 28, 2020 10:46 am
by Edmond
960mm ar front
390 between
John can you pls measure the gap from the top of the back seat to the back of the dog box so I can work out the angle
Posted: Mon Apr 06, 2020 2:31 pm
by John Alves
gap at top = 300mm
heigh of seat = 340mm
Posted: Tue Apr 07, 2020 8:40 am
by Donovan D
Are you referring to this piece ?
I have one like this that came off the 59/60 beetle, if you want it its yours.
