Autovilla motor conversion
Has thanked: 15 times
Been thanked: 41 times
Flag: South Africa
Re: Autovilla motor conversion
Post by Bugger » Mon Jan 23, 2017 6:53 am
Hi best conversion is the Golf motor with Hidden Radiator under neath the Bus
We have done a lot of them including a few Autovillas
I had a bay window with golf motor and towed my Heavy Double cab Microbus on a car trailer with it
0826008663
All these have Golf conversations
Very reliable
Flag: South Africa
Post by Bugger » Mon Jan 23, 2017 6:55 am
P
leon@bbo
What model do you have?: 1981
Flag: South Africa
Post by leon@bbo » Mon Jan 29, 2018 12:20 pm
Hi guys
I have a '81 Autovilla with a Toyota 2.2 4Y motor. Water-cooled.
In December it suddenly started overheating. We already replaced the waterpump, thermostat and even the water pipes from the radiator in front to the back. Also fitted a fan ontop of the motor to try and keep the motor cooler. Nothing helped.
Any advice will be highly appreciated
sean
Has thanked: 54 times
Been thanked: 181 times
Flag: South Africa
Post by sean » Mon Jan 29, 2018 12:47 pm
Your problem is you have a Toyota engine in a Volkswagen. It doesn't belong there. You will find if you throw out this contraption and install an original setup, your reliability will be restored.
leon@bbo
Flag: South Africa
Post by leon@bbo » Mon Jan 29, 2018 2:05 pm
Hear you! Unfortunately I bought it with this motor.
Terry Phillips
What model do you have?: T3,58,60,61beetle
Has thanked: 105 times
Been thanked: 99 times
Flag: South Africa
Post by Terry Phillips » Mon Jan 29, 2018 2:52 pm
Have you bled the system correctly. You must take thst carb off and fit a 1600 golf carb the original not cheap one you wont beleive the difference smooth more power better fuel consumtion. Thats if you cant get a aircooled motor as Sean says. Make sure you have the 2.6 Caravel radiator 2 speed fan and cowling and a big header tank to hold more fluid.my 2c worth.
leon@bbo
Flag: South Africa
Post by leon@bbo » Mon Jan 29, 2018 3:16 pm
Thx Terry, will look into that
Has thanked: 155 times
Been thanked: 387 times
Flag: Netherlands
Post by retrovan » Mon Jan 29, 2018 6:33 pm
Are you running antifreeze ??
Have a look at your thermostat as It gets an air bubble under it and it will not open.
The old Toppies always drilled a 3mm hole in the thermostat disk to allow the air to pass but not to effect the workings of the thermostat.
All old conversions had this done to stop air trapping.
When doing racing all my engines had this and never had heating problems.
1968 Fastback 2Lt.type4( Red)
2019 MeFusco Beetle Truck
leon@bbo
Flag: South Africa
Post by leon@bbo » Mon Jan 29, 2018 8:18 pm
Thx Herman. Are you referring to water-cooled or air-cooled?
Flag: Netherlands
Post by retrovan » Mon Jan 29, 2018 8:28 pm
No , water cooled, when you switch off a hot water cooled engine, it makes bubbles, and these sit behind the thermostat disk, when you start, the disk is cold with air behind it where the bellow is to sense the heat, so as the engine heats up, the air does not transfer the heat to the bellow and the engine overheats without the thermostat opening.
Now the little hole allows the air to pass through so this does not happen, and is so small it will not effect your normal cold start water flow.
leon@bbo
Flag: South Africa
Post by leon@bbo » Mon Jan 29, 2018 9:47 pm
Hi Herman. Thank you, it sounds like you have your fair share of experience! It makes perfect sense. I will definitely try it and will let you know the outcome.
Thanx again!
Leon
