Hatlapa Specht Compressor air works diaghram
hobb
What model do you have?: 73, 74, 77 busses
Flag: South Africa
Post by hobb » Thu May 03, 2018 3:01 pm
Hi all
I am looking for a manual or some idee to where the air pipes are running on a Hatlapa compressor. I have googled, but no luck so far, only on the later models.
Thanx
Henry
0815651825
Has thanked: 24 times
Been thanked: 149 times
Flag: South Africa
Re: Hatlapa Specht Compressor air works diaghram
Post by Dawie » Fri May 04, 2018 9:47 pm
Is this what you have?
"Things should be as simple as possible, BUT NO SIMPLER THAN THAT."
"If something can go wrong, it will go wrong" (Murphy's law).
hobb
Flag: South Africa
Post by hobb » Sat May 05, 2018 12:26 am
Yes, that is the one with the 2 air cleaners.
Sent from my SM-G925F using Tapatalk
Chardivw
Oil Seal
What model do you have?: 78 kombi 2000l
Facebook: Snowater photography
Has thanked: 12 times
Been thanked: 15 times
Flag: Germany
Post by Chardivw » Sat May 05, 2018 12:24 pm
Very cool
Flag: South Africa
Post by Dawie » Sun May 06, 2018 10:50 pm
Another way could be to look for make and model of each controlling device, search for info and take it from there. The pressure regulator would control the unloader valve which releases pressure from compressor's head when tank reaches max pressure. Like on a truck's airbrake system.
Unloader valve could be on compressing-head where it prevents inlet valve from closing, or a device inline between tank and head. Unloader valve might also act when engine is stopped, to ensure easy starting. Speed regulator might simply be controlling the throttle according to tank pressure.
hobb
Flag: South Africa
Post by hobb » Sun May 06, 2018 11:56 pm
On image 2, there is an airpipe running from the head, which is connected to the dump vale when it reaches the right pressure, where does that pipe go to, you can see it runs past the left side aircleaner till behind the control panel. Where does that connects to.
