midmounting a beetle engine ?
- What model do you have?: beetle
- Facebook: vuyo dube
this ones for Bugger
is it hard to midmount a beetle engine like they have on fomula vees
what do you need to do ?
do you still have the all gears?
cooling problems when running in a beetle?
just want to know
thanks
V
just want to know
thanks
V
60s look 74 beetle
skype: afronotch
skype: afronotch
Re: midmounting a beetle engine ?
Hey,
A clever dude like Bugger simply turns the diff around inside the gearbox to make it work for mid-mount. All the gears still work the same.
Cheers
Cheers
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 321 times
You would need to replace the pan with a custom space frame chassis to mid mount the engine. Doable, but a lot of work.
I have a set of drawings for a space frame.......fig wrote:You would need to replace the pan with a custom space frame chassis to mid mount the engine. Doable, but a lot of work.
- Has thanked: 18 times
- Been thanked: 58 times
- eben
- Site Admin
- Been thanked: 54 times
Bugger... I've heard about flipping a g'box over a lot... with audi & alfa boxes too. But could you please explain to me what needs to be done to accomplish this? Are special parts needed or is it just a case of turning the orientation of the existing parts?
When talking flipping a gbox are you talking specific Beetle of the Audiand Alfaeben wrote:Bugger... I've heard about flipping a g'box over a lot... with audi & alfa boxes too. But could you please explain to me what needs to be done to accomplish this? Are special parts needed or is it just a case of turning the orientation of the existing parts?
Beetle you can fit the Diff from the opposite side it usually go in and turn the box around Not flipping it to make it midmount
The others you actually have to turn the Box upside down close vent holes and make new vent holes at the "BOTTOM NOW TOP" and new oil drain hole top now bottom
Kapiech
- eben
- Site Admin
Aah so for a beetle g'box you just turn the diff innards around but for the others you need to flip the box.. thanks... was always wondering about that.
- Has thanked: 191 times
flip the diff vs flip the box
I know a guy who split his diff when he fell off a mountain bike
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
Tony Z wrote:flip the diff vs flip the box
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- colignym
- What model do you have?: Beach buggy
If I may ask, if one does a mid mount (I am thinking Spyder replica) then how does one get the gear rod linked up as engine will be in front of gearbox, or am I just being stupid here?
I was wondering about that a few years ago as well, till I saw this Formula Vee at a Show in Pretoria in 2007 - had a close look at the linkage setup but *duh!* didn't take a picture of it!colignym wrote:If I may ask, if one does a mid mount (I am thinking Spyder replica) then how does one get the gear rod linked up as engine will be in front of gearbox, or am I just being stupid here?
The linkage did however look something like this - a bit more complex than a standard Beetle but I'm sure you'll figure it out -
- colignym
Thanks Pine,
That really helps. If I have a 5 cylinder Audi engine, (actually looks like it may fit midmount in spyder) then maybe something like this can be done? Maybe it is an crazy idea, but imagine the nice sound on this little kit car.
Would a beetle suspension be safe enough on such a setup? I am not talking a racing car, or a 200 kph car. I am thinking a nice sounding RSK, with a good 0 - 100 just for fun between robots.
Thanks for the pics
Thanks for the pics
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
can you post them for all to see??JohnHoffe wrote:I have a set of drawings for a space frame.....
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
You can build a custom gear linkage system to make the gears work mid mountcolignym wrote:Thanks Pine,
Thanks for the pics
and make a turnd around beetle suspension setup work with the 5cylinder motor you want to use just with some upgrades
