V8 Nightmare 2.1 WBX Turbo in Beetle
Re: V8 Nightmare 2.1 WBX Turbo in Beetle
beetle786 wrote:
Bugger wrote:You can run std box but this one is a Stg 1 that can sake Quite a bit of Power
what about the revs of the engine .
My Stage 1 and a special Built SFAS boxes I do fit a Longer Ratio 4th gear in them for
Lower RPM driving whan you got the power
beetle786
Camshaft
What model do you have?: 1968 + 1303
Post by beetle786 »
what would one of these cost and do i give you my own gbox to be modified .
Click to View . Custom Graphics for your Beetle/Bus
4029
PM Sent with pricing
Best is to give me a call then I will understand your needs better and can build you a box accordingly
pierre 082 600 8663 my phone is on atm
chopwet
What model do you have?: Ex: Type-1 WBX
Post by chopwet »
Bugger wrote:Poerformance wise the single in and single out works best and not split on the silencer in to 2
And space problems it is easy to spend 15K on a Exhaust system when you Quote a Client to ad a Turbo to a motor it will be R17K so
Buget is also a major factor
I can get carried away with Exhaust Systems as mentioned on the forum under a rant a exhaust shop wanted to charge R3K just to modify a Std Beetle Exhaust
So that is why no S/Steel and all fancy expencive stuff as to where the Exhaust that we have built will Flow(Flow which is the most important for me)
and get rid of the gasses
I know this is an old thread but are there any updates? Was the above quote an actual approximatel price for the conversion? Was the car already running fuel injection?
This car have actually come along way from then we actually got special Wossener 2.1WBX Turbo pistons commisioned by them that is installed in to the Sub and the Pistons alone was around R13K but they are really quality pistons it really took forever to get all the special commisioned parts together but we should start assembling this Bug Actually this comming Monday you welcome to give me a call Pierre 0826008663
chopwet
Post by chopwet »
That sounds exciting, thanks for the update. From reading through threads I thought that the standard WBX motor could handle a decent amount of boost on standard internals. I'm assuming you are aiming for higher levels of boost...
Yes we are aiming for much Higher Boost
Std pistons need to be machined down to lower the Compression for Turbo but can only take around 0.5 bar boost
EcLiPsE
What model do you have?: Syncro Caravelle
Facebook: https://www.facebook.com/izanenchristelle.pretorius?ref
Been thanked: 4 times
Post by EcLiPsE »
Any update?
Some pictures? Dyno graphs ?
