Hatlapa Specht Compressor air works diaghram
Posted: Thu May 03, 2018 3:01 pm
by hobb
Hi all
I am looking for a manual or some idee to where the air pipes are running on a Hatlapa compressor. I have googled, but no luck so far, only on the later models.
Thanx
Henry
0815651825
Re: Hatlapa Specht Compressor air works diaghram
Posted: Fri May 04, 2018 9:47 pm
by Dawie
Posted: Sat May 05, 2018 12:26 am
by hobb
Yes, that is the one with the 2 air cleaners.
Sent from my SM-G925F using Tapatalk
Posted: Sat May 05, 2018 12:24 pm
by Chardivw
Very cool
Posted: Sun May 06, 2018 10:50 pm
by Dawie
Another way could be to look for make and model of each controlling device, search for info and take it from there. The pressure regulator would control the unloader valve which releases pressure from compressor's head when tank reaches max pressure. Like on a truck's airbrake system.
Unloader valve could be on compressing-head where it prevents inlet valve from closing, or a device inline between tank and head. Unloader valve might also act when engine is stopped, to ensure easy starting. Speed regulator might simply be controlling the throttle according to tank pressure.
Posted: Sun May 06, 2018 11:56 pm
by hobb
On image 2, there is an airpipe running from the head, which is connected to the dump vale when it reaches the right pressure, where does that pipe go to, you can see it runs past the left side aircleaner till behind the control panel. Where does that connects to.
