Golf parts in a beetle
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Re: Golf parts in a beetle
Short answer, welcome.
Shitty Golof engine will fit. But u will need to fit a radiator, not easy. Same with a nissan 1400 engine, these are all carb models. So basically also like a bug.
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
What an engine part thatbugspray wrote:so ja i want to maybe use parts from a golf mk1, is it possible??...and possibly engine parts like maybe wiper motor
blah blah blah.... heard it all before. If you really want to reduce your carbon footprint, use public transport or buy a bicycle or a pair of decent walking shoes.
As for a good engine conversion.... take a standard 1600 beetle engine. Get it reworked properly with new heads, new valves, and get everything remanufactured correctly. End result, brand new 1600 engine. then up the Compression ratio slightly to 8:1 and stick on a new carb (stock replacement). Viola, you have an engine that will last you the next 30 years if you maintain it properly
- OD_1
- Oil Seal
- What model do you have?: 1976 1600S
@ Pine!
Thanks all for your feedback... very informative. I've got lots to consider...
In regards to the Golf engines that fit the beetle. Whats the exact makes.
Thanks for your time people!
- karmakoma
VOLKSWAGEN makes golf engines
Stick to the beetle engine, have a look at millions of webpages,beetles can, and still do,travel vast distances all across the world.
Like the other members mentioned, you have to have a well maintained engine, granted. But there is absolutely no reason to be worried that a beetle engine cannot handle it. Why do you think there are so many still around? Because they were built to last.
My 2c....
My 2c....
- OD_1
- Oil Seal
I said make... but i meant model...
Ya.... I've been talkin to lotsa folks today and it seems that the beetle probably could make it on long distance trips... I just hope that it'll be able to do so on a student budget...
- Has thanked: 42 times
- Been thanked: 207 times
In your case, also consider the late 1300 dual port beetle. It has the same power as the older 1500 single port. Uses less fuel, less emissions, while driving at the same speed as a 1600. Just make sure it has'nt been modified to take 1600 pistons/sleeves.
The 1300 dual port was not much cheaper than the basic 1600, but was preferred by many companies at the time because of it's lower running cost.
- OD_1
- Oil Seal
Thanks for the tip...
I've been looking for a 1976 Super Beetle... These i believe they are normaly 1600s... is this true?
- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
Hi guys I've fitted a golf steering lock ignition housing to my beetle works great and the steering locks .
- beetle786
- Camshaft
Golf mirrors on a beetle
hi does anyone have pics of golf mirrors on a beetle and how are they modded to fit and also how good do they work .
thanks guys hope some one can help.
- bugspray
- Floorpan
If you really going aftermarket. Look at the bullet mirrors autostyle sells, they are a couple of hundred bucks, and drill into the door or slightly modded into the existing bug mount.
- beetle786
- Camshaft
- bugspray
- Floorpan
