Type 4 2366cc engine
Get your parts here
Re: Type 4 2366cc engine
Hi Ok My Buyer wants Type 1 when I do his car so Will pass on this one thanks
Guys you can for the life of you not build this engine for what it is getting sold for so it is a bargain
AirPower
Been thanked: 4 times
Post by AirPower »
Yes I know and totally agree, let me just explain my offer - I'm really only interested in the pistons/cylinders.
And of course I'm a cheap skate :lol:
4agedub
Been thanked: 13 times
Post by 4agedub »
This is what you will be getting with the engine... so it's almost a install and go for a beetle t1 to t4 conversion
-Points distributor
-Plug leads
-Ignition coil
-STD oil cooler
-Upright fan conversion crankshaft pulley
- 5x STD type 4 carburetors with intake manifolds
- Home made upright fan housing, needs some trimming and bracket
- Generator and fan, condition of gennie unknown
- 2lt flywheel and pressure plate
- 2x Exhaust manifolds
I installed the carbs, exhaust manifolds and distributor tonight and fired her up. She fired up one time with good oil pressure straight away. I'll leave everything hooked up, so the engine can be started.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
Coenie Nolte
What model do you have?: 1600 Beetle
Post by Coenie Nolte »
Ek stel baie belang in die motor.Wat is die kanse om die kompleet motor te kan koop.Ek bedoel insit en start.Weet jy dalk wat is die kilowatts en torque van die motor en is dit geskik vir elkedag gebruik in n pypkar?
Groete Coenie
4agedub
Post by 4agedub »
Hi
Die bottom end is heeltemal kompleet. Soos in die foto.
Wat nodig is:
1.Bracket vir fan housing (die housing wat ek saam supply was nie op die enjin vantevore nie, so hy moet getrim word en nodig 'n mounting bracket)
2. 1800 type 4 flywheel assembly, ek supply 'n 2l flywheel saam die enin wat nie straight pas in 'n beetle ratkas nie. Jy kan die 2l flywheel maak pas deur om die bell housing bietjie te grind)
3. Exhaust sisteem
4. Die carbs wat saam die enjin gaan is hopeloos te klein vir max performance, so iets soos 'n stel 40mm idf or individual throttle bodies kan help
5. Vir elke dag gebruik sou ek voorstel om 'n groot external oil cooler ook te installeer
Die enjin is tans op 'n chassis en kan start.
Ek is nie seker watse krag maak die enjin nie.
4agedub
Post by 4agedub »
Price drop bump R7500.00
4agedub
Post by 4agedub »
Sold
Who ever bought this got a Bargain
danie001
What model do you have?: 1966 vw beetle
Post by danie001 »
good day,
I am looking for pistons ans sleeve kit for 914 vw/porch motor
pistons are over sized pistons 103mm
Kind regards
Danie
4agedub
Post by 4agedub »
Hi, I have a new set of FAT performance 103mm barrels without pistons and a set of Deutz used cylinders with forged pistons available. Message me if you are interested.
danie001
Post by danie001 »
Good day,
I am looking for over sized pistons 103 mm
Struggling to get parts in south Africa
Any suggestions????
Kind regards
Danie
0710662526
4agedub
Post by 4agedub »
The deutz cylinders I have have been opened for 103mm
malcolm13
What model do you have?: 1964 Splitty
Post by malcolm13 »
4agedub wrote:Hi, I have a new set of FAT performance 103mm barrels without pistons and a set of Deutz used cylinders with forged pistons available. Message me if you are interested.
Hi
I am interested. 0824692894.
