Used 1300 TP cylinder heads
Get your parts here
Bratjie
What model do you have?: 74
Post by Bratjie »
Hi guy's, I have two 1300 twinport cylinderheads for sale, reasonably good condition, R 1000.00 neg,
PM me,
Esté robusto, ser fuerte!!!!
73 Beetle project
Re: Used 1300 TP cylinder heads
PM sent :zhelp:
louisvr45
Post by louisvr45 »
how does the tp heads differ from 1300 to 1600?
Sambabus
Short Block
Has thanked: 39 times
Post by Sambabus »
the 1300 heads have three more cooling fins than the 1600 heads............. :shock:
:twisted:
Bratjie
Post by Bratjie »
As far as I know the only difference is the circumference of the chamber where the sleeve slips in, it measures 90mm across.
73 Beetle project
louisvr45
Post by louisvr45 »
lol and is it for a smaller barrel?
slak
Has thanked: 7 times
Been thanked: 32 times
Post by slak »
The difference is 1300 heads will seal on a 77mm sleeve if u want to fit them to
a bigger sleeve u would have to have them opened on the sealing area when u skim them
and some of the older 1300 heads have 33mm intake valves but if they have 35.5mm intakes
u'r smiling :D
other than that there is no difference on twinport T1 heads unless they'r not oem but that will take
alot of unneccary research :wink:
U Only Live Once Right !!!
Bratjie
Post by Bratjie »
BUMP for R 800,00 the set
73 Beetle project
Chucker02
Facebook: chattingh74@gmail.com
Post by Chucker02 »
are they still available? very interested
louisvr45
Post by louisvr45 »
Bratjie wrote:Hi guy's, I have two 1300 twinport cylinderheads for sale, reasonably good condition, R 1000.00 neg,
PM me,
my fleetline heads looks very close to this one it also have the 3 lips on each cylinder face. did they used 1300 heads on fleetline?
Bratjie
Post by Bratjie »
Chucker02 wrote:are they still available? very interested
I have one dib's on them pending a lookover on saturday,
Additional info: upon closer inspection I have found that the heads do have hairline cracks between the valve & spark plugs,
so it's up to you to decide, I'm sure this is repairable,
73 Beetle project
Bratjie
Post by Bratjie »
Heads are still available,
73 Beetle project
Skymac
Post by Skymac »
would a 1600 cylinder fit on a 1300 block?
slak
Post by slak »
on the block yes , on the head not without machining
