Hi all
I have dual 34 Pdsit carbs with type 1 bug intakes and linkage. New seals have been added to the carbs. The only thing u need to make it work are air filters.
I would like to stop them for a single df downdraft setup (with intake) or a dual idf set up. I would add a cash difference if need be
(SOLD)Twin carbs w/linkage and intakes to swop
- What model do you have?: 1990
- Has thanked: 4 times
- Been thanked: 98 times
Re: Twin carbs w/linkage and intakes to swop
How does that linkage work / fit?
More pics will help.
2 bolts on either carb hold the linkage with a arm that goes down to the throttle body arm. Will send more pics later
Looks to me like the linkage is going to have a problem getting thru the Alternator / genny?
