"Recon" engines from R5.3k
Get your parts here
Been thanked: 321 times
Has anyone bought an engine from this advertiser? Experience?
The consensus is that one can't properly rebuild a type1 engine for less than R15k.
https://www.gumtree.co.za/a-car-replace ... 0012726809
Eugene
Has thanked: 59 times
Been thanked: 65 times
Re: "Recon" engines from R5.3k
Post by Eugene »
You see...I always knew these so called engine re-builders were ripping us off :-(
Has thanked: 191 times
Been thanked: 487 times
piston and cylinder kit R3000
grinding crank and refurbishing rods R2000
Oops, where does he cover his time and addition parts needed to actually take the engine apart, linebore, new oil pump, gaskets, new valves, new guides or resize guides....
its just not possible.
But hey, the beetle is notoriously unreliable isnt it? It must be normal
73type2
Has thanked: 141 times
Been thanked: 100 times
France
Post by 73type2 »
It all depends on his definition of "recon".
Has thanked: 42 times
Been thanked: 207 times
Post by Dawie »
Re con... "Conned for a second time"?
73type2
France
Post by 73type2 »
Dawie wrote: Fri Dec 01, 2017 10:04 am Re con... "Conned for a second time"?
That must be it! I've been re-conned, from car restoration to property deals, but I don't learn. I think I trust too easily.
slak
Has thanked: 7 times
Been thanked: 32 times
Post by slak »
I have Personally seen a bill from a reputable engineering shop to a very reputable engine builder
for all the engineering done on a stock standard engine with balancing before parts are bought
JUST machining recon heads , linebore ect. and it was almost twice what this guy charges for a whole complete
recon engine I Promise U it is impossible U WILL BE CONNED if U go for that "Deal"
U Only Live Once Right !!!
spicydave
Oil Seal
What model do you have?: 1973
Been thanked: 15 times
Post by spicydave »
Then I've scored with my motor that was just rebuild
Oom Franz that did the rebuild gave me a new flywheel, crank shaft and barrels he had stacked in a cupboard
The complete motor build cost me R9000 with the engineering works a extra R3780
The most expensive parts was the piston kit @ R2600 included in the R9000
Been thanked: 539 times
My 1st typr 4 motor before going to Arno at Villiersdorp, was a recon,
The pistons had the holes welded up, the then the new parts...
New rings on the old pistons
New bearings on the uncut crank
New bearings on the conrods, and a new spacer to take up end play.
Motor ran, no oil leaks
No smoking
As always, I do not take it at face value and sent the engine to Villiersdorp.
Thank goodness I had it rebuild the right way
Had years of pleasure out of it now.
