Hi guys n girls!! I recently purchased a 718RSK replica body on a relatively decent floorpan. Its not a shape I've seen before, as I previously had a 2lgolf motor in one with a healthy turbo setup. I have attached some pics, maybe someone knows where the body was made?
I will be rebuilding the twinport motor with a scat bigbore kit to make it 1800, already have a nice msd ignition kit of dizzy, leads, ignition module and coil for the setup.
but I need the door hinges and latches, windscreen with or without a frame, headlight covers (the perspex ones that seal up the actual headlight) and maybe some period correct gauges... If anyone has or knows where I can find these parts in jhb pls let me know...
Thanks in advance, Malcolm 0827984476
718 RSK parts needed!!! any info appreciated
- What model do you have?: 1969 beetle hot rod
- Has thanked: 6 times
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
Re: parts needed!!!
It's a standard RSK Spyder Replica. Contact Universal-products.co.za Or google porsche rsk spyder.
Enjoy, it's great fun, like a large go-cart.
