Aircooled VW South Africa • Safety relay info for using electric fuel pump
Posted: Thu Dec 11, 2008 2:02 pm
by eben
To make sure the electric fuel pump only runs while the engine is running(ie. stops in an accident) do the following:
Go to a parts supplier/scrapyard and get the following relay from them:
321 906 059 C
A good source would be an FI golf or jetta with mechanical (CIS) injection.
Connect the terminals up as follows:
This relay will cause the fuel pump to run for 5 seconds, to "prime" the carbs and then it will only continue running if the engine is running.
As soon as it detects through the coil trigger wire that the engine has stopped, the fuel pump will stop too.
I had a DIY setup running from the alternator warning lamp to do the same thing but the problem it causes is that it doesn't prime your carb if it has been standing.
And rememeber.... net pampoenkoppe, don't have safety relays on their electric fuel pumps :mrgreen:
Re: Relay info for using electric fuel pump
Posted: Thu Dec 11, 2008 2:14 pm
by Blitzkrieg
I wonder if Goldwagen keeps new ones like these?
Posted: Thu Dec 11, 2008 2:25 pm
by eben
ask splitfan
Posted: Thu Dec 11, 2008 6:07 pm
by splitfan
Hey Guys
I got a pm from Eben are you refering to the k-jet tronic injection as found on the mk1/2 gti's and cti's ?
Im sure this is it cos thats the only injection system that "primes" the injectors because its a mechanical system the relays are available from g/w there are two options the o.e relay @ R310-00 and a "local or pirate" relay @ R120-00 i only stock the o.e relays but can order the alternative if you like just gimme a shout :wink: If you are not close to me the part no's are : A216- for the oe and A2970 for the alternative, remember prices at other branches might be more as i try and "look" after my ac family :wink: :wink:
Posted: Thu Dec 11, 2008 6:11 pm
very very interesting, looks like I might have to change my relay...
Posted: Thu Dec 11, 2008 6:16 pm
by eben
I think the 2.1 kombi's had them too as I could rember the pump running a couple of seconds when you turn the key but not start it. :)
PS thanks splitfan!
Posted: Fri Dec 12, 2008 4:50 am
by fleetline15
yeah my 2.1 Dc did the same.PM
Posted: Fri Dec 12, 2008 2:43 pm
by BARON
The first thing I did to my Porsche was to change the head lamps to 100w and dim to 85w with relays. Although I put fuses in the system I m still a bit nervous with the battery next to the tank ---what will happen in case of a accident---and the nice fat live wires in there.
So this can also sort my problem in cutting the lights live wire in a accident------but then again the car will burn before the engine stop running.
Ok good idea but shit plan sorry I wasted your time.haha
cheers
baron
Posted: Fri Dec 12, 2008 2:59 pm
by Blitzkrieg
I've just read online that CIS is just another name for K-Jetronic. So that's the correct relay for our application here :D
Posted: Mon Jun 15, 2009 9:42 pm
*Bump*
For everyones info
Posted: Mon Jun 15, 2009 11:01 pm
by Dirk
Sticky please :D
