FlagBuggy Return progress
Has thanked: 25 times
Been thanked: 160 times
Flag: South Africa
Re: Flagbugy The slow Return
Post by Dawie » Fri Sep 28, 2018 2:40 pm
Vinnige Vlagbesie
"Things should be as simple as possible, BUT NO SIMPLER THAN THAT."
"If something can go wrong, it will go wrong" (Murphy's law).
Has thanked: 17 times
Been thanked: 49 times
Flag: South Africa
Re: FlagBuggy Return progress
Post by Bugger » Fri Sep 28, 2018 9:27 pm
Dawie wrote:Vinnige Vlagbesie
Kaptein
Has thanked: 2 times
Flag: Germany
Post by Kaptein » Sun Sep 22, 2019 4:12 pm
Bugger wrote:
Sun Feb 05, 2017 10:27 pm
Well rotary plan changed I bought a 3SGTE 2L Toyota turbo motor from a friend and going to use this motor rather
As I can use Launch control as the Rotary does not like that and Launch control is much softer on the Gearbox
Hi Pierre,waar kan ek so ń adaptor kry 3sgte na kombi gearbox?
Flag: South Africa
Post by Bugger » Sun Sep 22, 2019 4:24 pm
Hi ek het n kit te koop
0826008663
Flag: South Africa
Post by Bugger » Mon Oct 14, 2019 7:00 pm
Fuel system upgrade
Going all #10 size Ethanol compatable
Fuel hoses with All FTF fittings ImageImage
Flag: South Africa
Post by Bugger » Mon Oct 14, 2019 7:01 pm
Sketch of my Race suite layout with the Flag theme Image
