Line boring and Automotive Machine shop capabilities
Been thanked: 57 times
HI Guys
Some Good news :drunks: :drunks: :drunks:
As some of you might Know Vdubtech have Bought our own Line boring Machine :hangloose: :hangloose: :hangloose:
We Must Thank IMPI for his Assistance and Training with the line boring machine :zhelp:
We are busy setting up the machine shop and will be able to help our Fellow Enthusiasts to get the Job Done RIght
We do have the Ability to skim the Casings and Re size to Previous size or following size up
Brass gears clearance will be machined to fit
We Prefer to do the Line bore with supply M/Bearings and Cut the Crank then Bearing clearances can be sorted
Pls Fire away with any Questiones regarding the Machining side of Things
Pierre 0826008663
Vdubtech Eng
www.lineboringeng.co.za
1 Richdale rd cnr Shamrock
Primrose
Germiston
I will post some Pics as we do Machining for you guys to see.
Re: Line boring and Automotive Machine shop capabilities
Our first casing that got the SkimImageImage
Just an update
Vdubtech bought the last bit of machining tools and equipment Mc Donald's eng had
We required a big milling machine to do the Casing
Skimming and opening the casings and heads for Big bore kits
We do from basic to all required machining on the Aircooled motors
