These following pics are from when I did the disk brake conversion in the front, renewed and replaced the back drums, new wheel bearings all round, I had the master cylinder sleeved with a stainless steel sleeve as I couldn't find a new M/C for a right hand drive SUPER, did all new steel sections on the brake line as well as the flexible lines, I also fitted new CV joints at the back and new hand brake cables.
Here's the start of everything - http://www.aircooledvwsa.co.za/viewtopi ... 06#p265406
The brakes getting stripped off the car..
A right mess with slave cylinders leaking all round!
Brake fluid..
