The place to ask your "Stupid Questions" thread!!
Re: The place to ask your "Stupid Questions" thread!!
If you left your money at home,or the cops are chasing you and need a diversion(don't ask),you can just drive through!
Blitzkrieg wrote: Does anyone have the dimensions to make a rolling support/dolly/watseding (for the want of a better term) that the body is resting on? I need to have one like that made for my own fasty...
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
- 1972
blitz i can get them for you just give me sometime
- Has thanked: 235 times
- Been thanked: 234 times
That should be a relatively simple job to make one - the outer dimensions of you chassis will be exactly the same. If you think about it, you can actually take an old chassis and mount some heavy-duty castor wheels on it to make it mobile.Blitzkrieg wrote: Does anyone have the dimensions to make a rolling support/dolly/watseding (for the want of a better term) that the body is resting on? I need to have one like that made for my own fasty...
My (stupid) question is - WHY do you want one of those?
I think the main reason it was made, was to move the body around in a workshop area to make some space at the close of business in the afternoons in order to fit as much cars as possible in a workshop.
- 1972
pine it is much easier to move the body round and even the pan if that is if you doing a pan off compleate resto otherwise its a wate of time building one blitz i have the dimentions somewhere as with the metal left over from my body and pan rottissirie i am going to make one aswell
- vader
- Has thanked: 9 times
If you didn't have hands would you wear gloves????
Then why do seatcovers without breasts wear bras???
Makes things a lot easier when you want to move a car (especially an ACVW) with no suspension around the yard. Also makes it easier to load an ACVW with no suspension onto a trailer...Pine wrote: My (stupid) question is - WHY do you want one of those?
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Is "maiden" a gender specific term?
Can a bloke (not frm Cape Town) go on a "maiden voyage"?
- vader
Only if he is a tail gunner....
- Tom Bishop
- Single Port
- Been thanked: 5 times
Something I want to Know.
Behind goods trains you see cylindrical carts being pulled. Some are V’ed, in the middle, to the ground and others to the sky.
Why?
Why?
MAybe... V in middle - 1 tank
lower section on each end = 2 tanks
- Dirk
- Been thanked: 3 times
If I remember correctly it has something to do with the temperature at which the content is being loaded.Behind goods trains you see cylindrical carts being pulled. Some are V’ed, in the middle, to the ground and others to the sky.
If its cold it has to go into one kind and if it's hot it has to go in the other kind. Has to do with how the tanks expand and contract.
Don't quote me on this though, I'm probably wrong.
`68 Beetle
`66 Fastback
'90 Sunpacer
`68 Beetle
`66 Fastback
'90 Sunpacer
- vader
I would say it had to do with a gas or a liquid.....
- vader
Why do seatcovers wear skirts with slits up to their hips and then walk around the whole day holding it closed?
Why do seatcovers wear low v-neck tops which makes their boobs hang out and then get mad at you when you look at them?
