NON-VW Based Buggy
dsmbuggy
What model do you have?: unusual
Re: NON-VW Based Buggy
Post by dsmbuggy »
bought this windshield for $50.
It is from a 1961 Healey Sprite.
I am mounting it directly to the cage trough home made brackets.
With the 2 halves of the hood in place you can se by how much I had to widen the front of the body.
New ideas do not scare me, old ones do.
Coming along very nicely, but it looks as if the front is wider than the rear. You don't seem to have cut the rear body parts.
Has thanked: 235 times
That windshield fits it perfectly! Now store it away somewhere safe while you work on the rest of the buggy :wink:
dsmbuggy
Post by dsmbuggy »
I did some work on the hood.
First blend the vent in:
The vent is glue with epoxy, then I filled the gaps with bondo and glass on top for a crack free smooth surface.
I also started the suspension towers covers.
My wife was so nice and gave me an old Tuperware bowl.
I filled it with fiberglass and resin.
Let it dry and pulled the stuff out.
Then cut in two pieces.
first try fit.
Ok that is better.
Glue with epoxy.
Glassed in.
It is not looking awesome but it will work for now.
Nice work! :hangloose:
You must really be in the wife's good books - Tupperware (even old ones) is SACRED here in South Africa... :shock:
you are fkn nuts!!! I love it!!
Been thanked: 21 times
Post by Ron&Gill »
What's that orange sticky-out bit in the front, and what are your plans with it?
It looks like some kind of vacuum unit?
Post by Ron&Gill »
Ha! It's a waste gate. It's a turbocharged engine.
slak
Has thanked: 7 times
Been thanked: 32 times
Post by slak »
waste gate for the turbo :?:
U Only Live Once Right !!!
slak wrote:waste gate for the turbo :?:
yes, used to bypass exhaust gas past the turbo instead of through it
dsmbuggy
Post by dsmbuggy »
Ron&Gill wrote:What's that orange sticky-out bit in the front, and what are your plans with it?
Yes it is a waste gate.
It opens to bypass the exhaust gas when the desired turbo boost is reached.
It is internal in most oem applications but becomes external when you use big aftermarket turbos.
I actually like the fact that it is sticking out.
Post by Ron&Gill »
Look at the wastegates on my engine:
viewtopic.php?f=23&t=10290
dsmbuggy
Post by dsmbuggy »
I started the hood spoiler yesterday.
I cut the hood so it clears the wipers.
Check the top curvature
Fabricate some bracket to hold it in place
And glass it
dsmbuggy
Post by dsmbuggy »
I received most of my new fuel system.
It should be safe for around 600 HP.
The weakest link being the Bosch 044 fuel pump.
The only thing not in the picture is the AEM big bore fuel rail.
