New Old Spares
- Been thanked: 24 times
New Old Spares
One of the member's hunt for a petrol pump had me going through my list of "connections"
I came across a guy that bought the complete stock of Goodies Motor Spares in Pretoria when they closed shop. This company specialised in spares for old cars (before 1970). The stock was moved to his plot near Krugersdorp
If you have a sample of what you are looking for, he is available over weekends to try and help you out.
To respect his privacy, PM me for his contact details, and I will pass on his phone number.
Re: New Old Spares
I always wondered what happened to that stuff after Goodies went belly-up.
They used to be in Bosman Street,next to American music,then they built that new building in Church street,and I think that is where it all went wrong.
Re: New Old Spares
Isn't he the same guy on the forum who posts with a name starting with an H and ending with a P? Owns a Ghia?
- lowlight
- Been thanked: 14 times
Re: New Old Spares
I bought long ago Ghia tail lights in Church street, also some Chev fleetmaster carb spares.
- Clutch
- What model do you have?: 59 KG
- Been thanked: 22 times
Re: New Old Spares
There is a lot of stuff for many makes and models - but not that much ACVW stuff left.
I took a bakkie load of ACVW stuff to Ferdie Radel when he redid my K/Ghia motor and also sold quite a lot at the Piston Ring, Ferdie and Air Cooled Day swop meets.
As for ACVW I still have quite a lot of engine bearings, rings, some valves, valve springs, oil pumps, cables, ignition items, 6 Volt bits, some suspension bits, some mountings, a few used hubcaps, rim or 2 .... No body parts.
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Re: New Old Spares
Hi Hubcap, I'm looking for some hubcaps for a splitty and the clips that go on the wheel to hold them in place.
Re: New Old Spares
Sorry Hubcap if I opened a can of worms.
Maybe you can help.
I am looking for a set of balljoints (left an right) as well as a 4 hole rim for my 67.
Maybe you can help.
- Clutch
Re: New Old Spares
I have some hucaps - both painted and chrome. All are used and will need some attention - will try and take a pic when I get a chance.
Hubcap clips definitely not.
4 hole rim definitely not.
I have heaps of balljoints - mostly out of their packaging - if I have a decent pic or sample in my grubby paw, I can check.
- ChrisG
Re: New Old Spares
I need balljoints too, for an early bay. You got?
http://thegreatadventurer.com
Twitter: @TGadventure
- Clutch
Re: New Old Spares
Will need a sample for the balljoints.
Did some sorting out of piston ring sets. I have the following for ACVW:
1300 - 1 x .040
1500 - 8 x std, 2 x .020, 1 x .030 and 1 x .050
1600 - 1 x std, 1 x .020 and 2 x .030
1700 - 1 x std
1800 - 1 x std
1900/2000 - 3 x std
Also have a set for Golf 1100 and Passat 1300 - both std
R150 a set.
1300 - 1 x .040
1700 - 1 x std
1800 - 1 x std
1900/2000 - 3 x std
R150 a set.
- Been thanked: 98 times
Re: New Old Spares
I can get ball joints for bug & bus. These are quality OEM replacement parts.
Bus R400 each need 4 top & bottom are the same.
BJ beetle R330 each need 2 top & 2 bottom.
Rui 082 830 6493
Rui 082 830 6493
- Tristram
- What model do you have?: 1974 luxbug
Re: New Old Spares
Hi hubcap im looking for a oil pump for a 1600 bug no clue of year unfortunatly, know u mentioned you had some? Regards Tris
Tristram
1974 LuxBug 1600 AKA PIG
"Im a slave to my aircooled"
- forcecooled
- Single Port
- Been thanked: 5 times
Re: New Old Spares
Hi ,Juliet mike victor victor,
I have a 67 bug as well - I also have a lot of stuff for them, and it includes a set of genuine VW ball joints in their boxes. I probably wont want to sell them, but once my move is over and I have a chance I can let u have the part no's and you can check if VW still have any stock
Dont laugh
I got a set of float bowl gaskets for SP kadron carbs from Lindsay Sakers a while ago!
Better than a poke in the eye with a sharp stick on a dark night i would say
Bill
084 612 1389
Dont laugh
Bill
084 612 1389
