Rotary into bug/bus
Racer-X
- What model do you have?: caddy
Rotary into bug/bus
Hi guys,
How much do one of these conversions cost?
What parts do u need?
do u need to change the gearbox?
is it easier to do it on a bus as opposed to a bug?
what fuel consumption can one expect with a rotary instead of an aircooled engine?
cheers Julien
cheers Julien
Re: Rotary into bug/bus
Julien,there has been quite a few discussions around this subject.
The best person to speak to is Bugger.
- dubster
- Been thanked: 3 times
A rotory is heavy on petrol,but when you put in a rotor its more for power than economy,and yes have search for this subject or pm bugger,he himsef has a monster turbo rotory bug...id say a bug is easier its been done for ages...
1974 1300tp type 1
kart kraft 1717cc buggy
- Has thanked: 19 times
- Been thanked: 58 times
Hi Julien
Visit my Web site http://www.buggertransmissions.co.za
and send me a E-mail from my web site then I can send you a list of things you will require to do the conversion
I had a Rotary Turbo in my Double cab Micobus aswell and it was very funny racing the BMW`s past 190Km/h on the highway
So It does not matter where it will go in you will still have lots of fun playing with the other cars on the road
- dubster
Fuel economy???or is that taboo when speaking rotory?
1974 1300tp type 1
With longer ratios wich I also got in the DC the fuel is better than a 1.9 WBX but when you clean the Rotarys trought and give it stick it does come a bit thirsty but you enjoy every extra sent that is getting wound down the Exhaust
- dubster
Id smaak to go rotory turbo route with the buggy but then that just makes me like any other guy with a buggy that looking for more power...i wanna pass a windgat golf and have him see that its still the ''kak'' beetle motor and the rotory ruines that...but then again a rotory in a buggy must f@@@@@ckoooooooffffff!!!!
1974 1300tp type 1
I have done 11sec on the 1/4 mile before with a Aircooled so one word of warning is that be prepared to spend 2wice and a bit more to a Aircooled motor to get the same power as you would spend on a Rotor
I will be running my Aircooled motor in my Buggy again oneday
I have spend more than R50K on my motor and it is not even wild
It all depends if you want to build a realy usable daily driver or a toy for every day abuse I can give you a Guarantee that a ACVW is not going to sit with your abuse for long
- dubster
So i have seen,id like a acvw oneday but if i cant resist the speed bug i might pop in a rotory...can always go back...what is a ballpark figure for a rx turbo motor in a buggy?
1974 1300tp type 1
dubster wrote:So i have seen,id like a acvw oneday but if i cant resist the speed bug i might pop in a rotory...can always go back...what is a ballpark figure for a rx turbo motor in a buggy?
R30K with the Microtech radiator etc
- dubster
Isnt the scooby motor also in that range?id rather put that in for that money...anyway let me just qualify and then then i can have the buggy buggerd in a year or two...
1974 1300tp type 1
Racer-X
hey guys,
What would the fuel consumption be with a 13b turbo rotary motor in a:
1) bus
2) bug
R30k sounds like a lot of money to do a swap?
i take it that is with everything done, obviously.
but what about using a naturally aspirated rotary motor?
i imagine that would be a bit cheaper coz u don't have fuel injection and a turbo,
obviously still have a radiator to sort out though.
1) bus
2) bug
Fuel consumption depending on the right foot
But nice drivin around 8-12 Km /L
SOmetimes you will be going over R30K
Going n/a will be around R10K cheaper with out the EFI
If you want to go N/A then you buy a Series 5 Turbo motor which has hight CR than a series 4
And have done some conversions like that
Racer-X
How about if u swap a rotary into a watercooled bus?
would it be slightly cheaper coz the waterworks are all there?
Racer-X wrote:How about if u swap a rotary into a watercooled bus?
Yes then you just need to build a back cross member to hold the motor and tranny in place
