Type 2 disk brakes
clement
What model do you have?: 60 Vrod, 62 Crew Cab
Type 2 disk brakes
Post by clement »
Hi Guys
I am currently sorting the suspension on my double cab and would like to upgrade to front discs, is anything like that available in SA or is the only option to get it from overseas?
Re: Type 2 disk brakes
Hallo Clement.Speak to calooker,I'm sure he can help you out.
Donovan D
Has thanked: 148 times
Been thanked: 73 times
Post by Donovan D »
Im lookin to do the same on my bus but am clueless, and kits from overseas are rather expensive,
and I do not want to loose the 205pcd, yes yes adapters but the wheels come out then,
Been thanked: 21 times
Post by Ron&Gill »
I've just had a set made up by Dave Rowley, they apparently put the wheels out by 15mm.
Donovan D
Post by Donovan D »
I saw the pic of that on your page, looks really really good !!!!!!
clement
Post by clement »
Ron&Gill wrote:I've just had a set made up by Dave Rowley, they apparently put the wheels out by 15mm.
Sounds good, how much does Dave charge for it if I may ask.
Donovan D
Post by Donovan D »
Me too please !!!...and will it work with dropped spindles ??
Post by 1972 »
As long as it is based on the stock spindle setup you will be sorted.
