4agedub
Been thanked: 13 times
Re: My ex type 1 turbo project (Changing to Historic Racer)
Post by 4agedub »
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
4agedub
Post by 4agedub »
Eina!
4agedub
Post by 4agedub »
Here's some pics of the racing.
4agedub
Post by 4agedub »
dubster
Post by dubster »
Hey louis...awesome racing on saturday was nice to meet you...i see the bug is having a hard time in the d class....what you gonna do about it?bigger stronger motor or tune the motor down so you can run in e class again?
1974 1300tp type 1
kart kraft 1717cc buggy
vuyo
Facebook: vuyo dube
Post by vuyo »
the rims looks so cool no yo! bug
60s look 74 beetle
skype: afronotch
4agedub
Post by 4agedub »
Nice meeting you too Dubster.
We're building a bigger engine with fuel injection! My fuel injection proposal was accepted by the committee, I submitted enough proof that beetle's were built with fuel injection.
For next year we will probably run my 2165cc engine. I've already ordered the new cam as well... Engle fk89 :P
dubster
Post by dubster »
Nou gaan hulle k@k!good luck louis...
1974 1300tp type 1
4agedub
Post by 4agedub »
I've started sorting out the rear fenders. Got a set of fenders from volkspares. I'm planning to mount them with dzus fasteners for quick removal.
Engine and gearbox is out as well for more mods :hangloose:
While stripping the car I've also found the oil leak... darn alternator stand broke off the base!!! Probably also part of the rear end smash damage.
4agedub
Post by 4agedub »
I've started fitting the fenders.
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
The lh fender fits perfectly, the rh fender needs to go to volkspares for some alterations. It has been cut too short :cry:
So far only one dzus fastner keeps the denfer in place, but it looks like it'll hold nicely.
4agedub
Post by 4agedub »
I've started assembling the big engine again. We need more hp!!!!
The engine is:
EMPI ally casing
78mm crank
94mm pistons and barrels
H-beam cromoly connecting rods
fk89 camshaft
Twin 48ida carbs
CB performance 044 super mag heads.
12.5:1 static compression.
The bottom end is assembled, the next step is to do deck heights and then port the cb heads. Will post pics of the heads when I start.
isnt that cam a little big for a race track? Surely its going to kill your low rpm torque.
