TRANSVERSE MOUNTED ENGINE IN BAY
RICKY-R69
What model do you have?: 76 kombi,1970 beetle
Post by RICKY-R69 »
Hi Guys
Do anybody know if it was ever attemted to fit a golf engine and gearbox transversely into a bay kombi? How difficult could it be? :?:
Been thanked: 98 times
Portugal
Re: TRANSVERSE MOUNTED ENGINE IN BAY
Post by calooker »
Seen several, v6 & v8 with difs as well as a 16v golf in a split bus, all midmounts.
Barry
Post by Barry »
Cut front off Golf, cut guts out of bay, wheel golf front under bay & weld, tie up the steering solid(you did want the engine in the back right?) and you're good to go....... :wink:
Barry
RICKY-R69
Post by RICKY-R69 »
something like this.
CooP
Post by CooP »
http://www.vwkd.co.uk/ has loads of info about similar conversions.
Size does matter
Sambabus
Short Block
Has thanked: 39 times
Post by Sambabus »
I would like to be the first to ask you please please dont do that to youre bus,its not an easily reversably conversion and it doesnt look nice,....
DDunc
Post by DDunc »
Yes please don't.
Then its not an ACVW anymore :bn:
1969 Sunroof Beetle - Scratch Build in progress
1967 Beetle with 4 stud wheels and front discs - next in line for project
I know of someone who will be doing a Subaru midmount conversion in a split D/C.
Now that promises to be a beast :hangloose:
RICKY-R69
Post by RICKY-R69 »
I am not planning to do that to my bus. Just wondered.
RICKY-R69
Post by RICKY-R69 »
But if I don't find a gearbox soon I just might have to!
BARON
Post by BARON »
Put it all on a subframe and bolt it to the existing chassis
Idont think it’s a good idea. You will have to do a lot of cutting. The bay engine bay will be big enough but the roof is to low.
.You will also will loose weight balance as the transverse engine will have a lot of weight high up. You will need to remove the spring plate/swing arms and install a Mc Pherson type suspension.
You will be much better of using a Subaru or rotary engine ---much easier fit and enough power
Then there is the roadworthy certificate issue. It will never pass in my area as you are not allowed to weld on suspension parts
This guy did it on a plastic Porsche and although he didn’t used a vw pan that chassis operated exactly like the vw rear end .
Ten when you are finished you have to deal with this
Cheers baron
Toyota engines in Porsche? :(
I think we have to start accepting it:
