Pictures say a thousand words.... so take a look at my side by side video comparision, Broken and Fixed.
Heres the link; VW T4 clutch pedal broken as usual vs. VW T4 clutch pedal fixed for £12 by VJ boatyardbuses | YouTube Doubler | Mashup Helper
Or read on for the 'thousand' words;
The Volkswagen T4 Transporter / Caravelle / Multivan has a very common problem.
The clutch pedal mounting bracket cracks, which causes the clutch master cylinder to become loose and move as you can see in my 'VW T4 clutch pedal broken as usual' video here; VW T4 clutch pedal broken as usual - YouTube
No big deal to start with.... but before long it will break completely, then your stuck without a clutch. It can also damage your master cylinder beyond repair, and crack the pipe leaving you with your footwell (and your shoes) covered in nasty corrosive brake/clutch fluid.
Up until now you have had a few choices, but all are expensive (some more than others) and time consuming repairs, requiring at least a few hours work.
Now though, you can spend just 10 minutes of your time fitting one of my clutch pedal repair brackets.
See the difference in my 'VW T4 clutch pedal fixed for £12' video here; VW T4 clutch pedal fixed for £12 - YouTube
They come powder coated ready to fit with all the nuts, bolts and washers you will need and best of all they cost just £12 (excluding P&P)
So don't delay, the longer you leave it the more parts break so the more money you have to spend on repairs.
Paypal me £18 (inc shipping) to boatyardbuses@aol.com and within a few days you can have the most common VW T4 problem fixed for good.
Cheers,
Neil (Jonesy)
VW T4 clutch pedal broken as usual ? Fix it in just 10 mins
