cool i changed mine to a 1300 Gbox as well ,, i must say it is quicker but i feel like i lost out in top end ??4agedub wrote:I'm running a 1300 gearbox with the rough gears. Standard syncros. The diff is locked. So the box is almost stock standard.
I've used this specific gearbox for very long now and I've never broken anything in it... and believe me I drive her like a hooligan. Launching at 6000rpm with bf drag tires.
its all over by 100 anyway - 160 at a push
If you take an M3 thru 1st and second, you.ve won, it doesnt matter that he comes flying past at 140, you still whipped him where it matters
yes that is true , i had a friend who bought hims self a brand new Ford Fiesta ST and he was goin on and on about till one day we took each other on on the drags strip !!! i had my MK! Golf 1979 with a equavalent of a 1.8 Topsport production motor with minor mods .. and in first second till the end of 3rd Gear i was infront of him a whole car lenght. so the morrel aof the story is acceleration is a must !
just think about it this way.... if the bug is ahead for any decent length of time, the M3 driver will never live it down, even if he catches and overtakes you....
- 4agedub
- Has thanked: 4 times
- Been thanked: 13 times
Hi everyone.
I had a quick thought today... On the turbo setup, it will be worthless running a intercooler as there is almost no airflow in the back. So I'm considering going for a charge cooler that uses water for cooling. I will then use a Golf vr6 electric waterpump and fit a small radiator in the front for the charge cooling.
Will check today what is available and what it costs.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
air to water intercooler.... good idea.
What I have heard that is pretty good is to use an oil cooler (if you cant fins a specific intercooler made for the application), get the cooler new and weld on a chamber around the fins. Use the water to pass from one side of the fins to the other (original air side) and route the charge air through the original oil side of the cooler. This apperently works quite well, you just need it to be big enough not to create a restriction in the air flow, because pressure lost here, adds to less pressure available at the inlets....
Good luck
Good luck
- vader
- Has thanked: 9 times
Here is an idea, what about putting the intercooler under the car next to the gearbox, that way it's out of the way and you have loads of space, can manufacture an air scoop underneath to redirect the airflow and you can use intercoolers on each side of the box. Speaking about the box a while back I got in contact with a dude in jhb who builds hydrolic box's for the formula ford series as they use the beetle box's. For 10k he would put a box together for you with the ratio's of your choice.
- 4agedub
Some news again...
I have not received my shipment from summit yet
They are still waiting for the turbo. I ordered a special turbo for my specific application.
I did however get my new dash. Lookie here
Digital! Started playing with it this weekend... very niiice.
