Ford V6 beetle
- Oil Leak
- What model do you have?: 2l kombi Pipecar
- Facebook: http://www.facebook.com/home.php?#!/gbramley
Ford V6 beetle
I am looking for a adaptor plate to fit a frod dierra v6 motor to a IRS beetle gearbox in a buggy. Does anyone know of a company that makes them or has one that will fit exactly. Thanks
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
Re: Ford V6 beetle
try http://www.giloeng.com
they can custom make you one .
why not rather go for a 1.8/2.0l golf engine
- Oil Leak
- buggyfan
- Long Block
Re: Ford V6 beetle
no ,you will still need an adaptorplate for a golf engine
- RICKY-R69
- Clutch
- Has thanked: 13 times
Re: Ford V6 beetle
The Golf conversion is rhe best. You will run into all sorts of trouble trying to get a V6 to fit in a Beetle. Biggest problem will be the weight of the engine. Anything is do-able ,but I doubt if you will be happy with the results. Keep it simple; Golf engine with carb has got plenty of power and no hassles.
- oldschoolgp
- Been thanked: 3 times
Re: Ford V6 beetle
If Gilo dont have it that they will be able to make it for you
Has any1 ever tried to put a Lexus V8 into a bus ???
i have seen a old toyota running 1 of those and its like a Horse on steroids !!!!!![Hang Loose :hangloose:](./images/smilies/action-smiley-035.gif)
![Computer work :puterwork:](./images/smilies/action-smiley-057.gif)
- arnocill
- What model do you have?: beamish buggy
- Has thanked: 6 times
- Been thanked: 4 times
Re: Ford V6 beetle
oldschoolgp wrote:If Gilo dont have it that they will be able to make it for you
Has any1 ever tried to put a Lexus V8 into a bus ???![]()
Arno van Wyk from Andreno motors in Villiersdorp got a double cab syncro with a lexus v8.
I've been in it once and that thing pulls like a steam train! only faster.
- Qkickslvr
- What model do you have?: Type 1 1976
Re: Ford V6 beetle
Rotary turbo is also an option. Had mine for a couple of months now. Very fun. Not much that keeps up. 180Kw on the wheels 260nm.
- Riekert
- Camshaft
- What model do you have?: 1964 Notch
- Has thanked: 111 times
- Been thanked: 23 times
Re: Ford V6 beetle
What did the conversion cost if I may ask?Qkickslvr wrote:Rotary turbo is also an option. Had mine for a couple of months now. Very fun. Not much that keeps up. 180Kw on the wheels 260nm.
- buggyfan
- Long Block
Re: Ford V6 beetle
- RICKY-R69
- Clutch
Re: Ford V6 beetle
Did my golf conversion for under 8K. Okay, I must add, everything was D.I.Y. Even the adaptorplate and flywheel.
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Has thanked: 3 times
- Been thanked: 5 times
Re: Ford V6 beetle
My personal favourite if you wanna stay a/c, Tuuurrrbboooo Tuuurrrbboooo Tuuurrrbboooo ![Laughing :lol:](./images/smilies/icon_lol.gif)
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
