Possible 3rd location of beetle chassis number
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
So we all know the chassis nr of a beetle is either on the pan or on the plate in the sparewheel well,
On the pan i got from Sthang there is no number stamped on the pan in the usual spot but i did find a chassis nr stamped on the inside of both rear shock towers .
has anybody else ever seen this??
Re: Possible 3rd location of beetle chassis number
I've seen that before - are you sure it is not the part no of the shock towers? What is the number stamped there?
buggyfan
Long Block
Post by buggyfan »
was thinking the same thing but if it was the part nr it would have been raised instead of punched.
113701***
this dates it to a 73 model........http://www.thesamba.com/vw/archives/inf ... dating.php
I think it is a part number, same as Pine.
Why don't you go to this site.. http://www.vwheritage.com/vw_parts_Beet ... try_GB.htm
and type in that number, and see if the parts that its on matches to your placement... :wink:
buggyfan
Long Block
Post by buggyfan »
Seems you are right regarding the part nr ......http://www.azbaja.com/ForumsPro/viewtopic/p=74867.html :hangloose:
