1. AS 41 case machined for 92's and clearanced for Engle W110 cam and street followers. Good used
2. Counter weighted and balanced Crank with rods Good Used
3. Mahale barrels and pistons 92mm Good used
4. Engle W110 Cam with straight cut gears and street followers New
5. Modified standard oil pump for external oil filtration Good used
6. 009 electronic Distributer Good used
7. 2x 36 IDF Webers Refurbished by Dave Rowley with linkages
8. CB performance wide glide sump Good used
9. Intake manifolds for Webers Good used
10. External oil filter base Good used
11. 2x gas flowed Cyl heads with new Stainless valves with 3 angle cuts and HD springs int 40mm- exh 35mm refurbished by basticks
12. All the rest of the parts except fan housing and oil cooler
Take all for 10K
SOLD!
Engine Parts for sale
- Been thanked: 98 times
Re: Engine Parts for sale
Some pics and importantly prices will aid the sale.
