I've finally got the corner trims to sit as I've always wanted them too. I'm chuffed to bits:-
These pictures show a clear difference between the original paint inside & the newer paint applied in 2006 outside, that difference will soon be a thing of the past:-
The trim is 3mm lower now on the tailgate & there are fewer clips, it looks like I used far too many clips,, both corners are spot on:-
The sides are nice & straight now & in line, even some of the holes I drilled yesterday were a few mm out, its a nightmare trying to line everything up. The secret is to do the corners first get them in line by using the tailgate piece, then work down the sides:-
