beetle 1303 imported model has disk brakes ,macphearson stuts ,irs ,round windscreen ,dashboard ,shorter bonnet ,fenders are diffrent front and rear has a 1300 tp engine . check out my post beetle 1303 in projects i've put some pics on there .google beetle 1303 to find out more .
the badge that fits on the "engine lid''
15" rostyle rims ,1972 Big tail lights for sale
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
Re: 15" rostyle rims ,1972 Big tail lights for sale
beetle786 wrote:ok then .i'm looking for a 1303 badge btw
Like the one in my avatar pic..Cyndi Kritzinger wrote:What is that?
Cyndi
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
yep thats the one have you got one for me .or 2x 1300 badges combined could make up one 1303 one maybe .
- riaanj
Just a bit more on that:beetle786 wrote:beetle 1303 imported model has disk brakes ,macphearson stuts ,irs ,round windscreen ,dashboard ,shorter bonnet ,fenders are diffrent front and rear has a 1300 tp engine . check out my post beetle 1303 in projects i've put some pics on there .google beetle 1303 to find out more .
you did get a 1600TP too, the 1300's were the 1303 base and 1303L if I'm correct and the 1303S was the 1600, some countries had the 1303S with fuel injection and trim and spec. was diffirent between the models, you did get a 1302 model too, it had a flat windscreen and longer bonnet and a steel dash (sometimes with a dashpad on it), the 1302's was 1971 & 1972 models only, with a 3 bolt strut, same as the 1973 yearmodels that was the first 1303's, august 1973 they changed to the 2 bolt strut(most of the front suspension parts are not interchangable between the 3 bolt and 2 bolt setups), the 1303 was manufactured in sedan form from 1973 to 1975 or 76, the cabriolet model was however continued until 1978. There is one special thing about the 1973 beetle regarding the bonnet, it was a one year only bonnet, the tip is ever so slightly more rounded than the 1974 & on models and it has no bump or raised piece at the base of the chrome handle where the 1974 & on looks a bit more square and it has the raised piece at the handle.
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- riaanj
The 1303 badge is like hens teeth in S.A. I didn't have one on my car & got lucky, I bought one off of a forum member here a while back..beetle786 wrote:yep thats the one have you got one for me .or 2x 1300 badges combined could make up one 1303 one maybe .
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- beetle786
- Camshaft
look out for one please .my bonnet is a little flat on the front .should be a 74 then .how do i tell if it has a 1300 motor or 1600 ,i do know its a tp motor it's the original motor .
- riaanj
The best way to check the engine displacement is when the heads are off the motor, measure the bore of the cylinder, the stroke is 69mm on the 1300 & 1500 & 1600 the bore on the 1300 is 77mm on the 1500 it's 83mm and on the 1600 it's 85,5mm - visually the motors look the same especially if they have TP heads on, the motors gets swopped out in the wink of an eye, mine was a factory 1300 base model 1303 but when I got it it already had the 1600 motor in it.beetle786 wrote:look out for one please .my bonnet is a little flat on the front .should be a 74 then .how do i tell if it has a 1300 motor or 1600 ,i do know its a tp motor it's the original motor .
P.S. will keep an eye out for that 1303 badge for you..
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
- beetle786
- Camshaft
will check it out when i redo the engine .
thanks
thanks
