Soooooooooo, had some time to tinker around yesterday as I was supposed to be working in the garden.
I have been putting off looking at changing the steering column to a thin shaft so that I could fit the steering wheel boss and set up from a SP so that I could fit the steering wheel. I've had my ring cut/ bent and welded already and now all I need to do is to pull off the material on my spare wheel and cut off the ring. ( I have 3 SP steering wheels now, I just can't get enough of them, plus they are dirt cheap).
SO I decided to strip both steering wheels and see what I could make a plan on. SP one is stripped and boss off..
One that was in the car, now stripped. Damn I hate this thing.
Then I saw that the steering wheel that was on there has an spacer in between the boss and the steering wheel.
So, I grabbed a slab of MDF and went to work to make a blank to see if it could be this simple. Basically came up with a spacer adapter that will use the old boss, but will be able to bolt the steering wheel to that with very little effort.
I didn't take a pic of the final trim ring, I'll snap a pic tonight when I take it off, but it works a treat, this way I don't have to use the massive back cover on the wheel as well, but now that it's on there, I don't know if I'm feeling it.
It lines up 100%, my gauges will be perfect behind it, but the center section is just too damn big, I don't know if it's just because of the fact that the outer ring is still so fat and chunky, or if the step at the back is just too big. I've decided to send in the ring and get one laser cut from ali and tapped and then roll it like it is for a while and see if it grows on me, one thing is for sure though, the outer size is just perfect. I think that once the thinner outer ring has been fitted and then trimmed out in wood with rivets, then it'll look better. It just looks so bulky there at the moment.
