OWN ONE OF THE FASTEST VW ENGINES IN SOUTH AFRICA
Occy
This is most probably the fastest VW engine in South Africa. This engine can do the following:
• Stationary - 60 feet in 2.8 seconds
• 0 - 100 km/h in 4.3 seconds
• ¼ mile in 13.2 seconds
• Top speed of 178 km/h
These are actual times officially recorded and can be verified.
The base engine is a VW 1600 twin-port. The original pistons in a 1600 are 86mm; these have been bored out to 94mm, making it a 2280cc engine. It has an Oetinger Crank. Eliminator Heads. Button Clutch. Electronic Egnition ( no points & condensors ). Oil filter & extended sump. Imported EMPI carburetor intakes with two 44 downdrafts with Weber 44 Carbs. Imported K&N air filters / air cleaners. Maling Oil Pump. And External oil cooler. Total cost of all the parts imported for the re-build ( mainly from USA ) was R60 000,00. That’s excluding import duties, workmanship and obviously the cost of the original engine. Only about 2000 km’s done since the re-build.
I also have the 1500 Beetle gearbox to go with the motor, as opposed to the 1600 gearbox that usually comes with the 1600 twin-port motor. VW experts will explain that the 1500 gearbox is a much stronger box which they use for racing to be able to cope with the much more powerful motor. It has a much better gear ratio with a longer 1st gear which is obviously better for the power underfoot. I not only have the 1500 box, but also a hydraulic clutch with a short ratio kit installed for faster gear shifts...!
Transform your buggy, beetle, kombi, hot-rod, or any other kit-car that is built on a VW chassis into a very fast, very powerful vehicle.
R 50 000,00 for the motor and gearbox
R 40 000,00 for the motor and box ( if you give me your existing reconditioned 1600 twin-port and box )
R 45 000,00 for the motor and box ( if you give me your existing non-reconditioned 1600 twin-port and box )
Would also consider swapping for a car or cruising motorcycle of same value…
Should you have any further questions or to view, please call Occy on 082 3694919
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
Re: OWN ONE OF THE FASTEST VW ENGINES IN SOUTH AFRICA
Picks are always welcomed... who assebled this and do you have more specs in terms of C/R , Cam , headwork and rockers ?
- Been thanked: 98 times
Sounds like an awesome engine but not to burst your bubble but whoever informed u about the capability and spec of the 1500 tranny have their info very wrong. A late 1600 tranny is a better option. For you to have a longer first gear you would need a aftermarket main shaft ATM one would set you back R13K to R15K. More defined spec on the motor will help.
- Has thanked: 425 times
- Been thanked: 543 times
As a 1st post, no one will take you serious, You have not even introduced your self or your interest as requested in you acceptance mail.
Please Go to the New Members introduction thread and lets have more info on you and what you do.
Photos of your ride and of this engine and gearbox would also help.
Then lets hear who done the mods on your engine and gearbox, and what exactly was done to them.
We keen readers you know..............
........................... and not so keen on "drop and run" adds
- Has thanked: 45 times
- Been thanked: 208 times
You mention that it has done 2000 kilos. Minus it's fan-housing. Only cooled by 2 hoses fed from a single T-junction. Possibly fed by electric fan not shown. Assume that was 2000 kilos of drag-racing, and quickly switched off after the quarter mile, otherwise it would have overheated badly?
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
Does not look like a very neat motor... probably built for a beach buggy for the occasional drag race meet. So I assume this motor has no real road reliability?
Dave Rowley from FFR would have built you a nicer neater looking motor for that money...
Having said that. .. Daves buggy does 0 to 100 km in about 3.8 sec and the quarter mile in the low 10 sec
m
m
Old School or Bust!
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
I like the end of the accelerator cable. Neat!
It looks like the intake ports are bigger than the cooling air ducts ...
And what's with the "window" cut in the cooling tin over No4 head? Can you give us more detail on the cooling system? What kind of pump? How much air flows through those ducts? etc.
I think Dawie may be correct on the type of use this engine has had; I doubt it clocked its 2,000km on a drive from Cape Town to Joburg. I would suspect that after 2,000km that engine has reached the end of its life ...
With such a highly customised engine we need a LOT more info and pics about its spec, what parts went into it, who built it, etc.
- dixtoy
- What model do you have?: 73 Beetle Patches
- Has thanked: 60 times
- Been thanked: 37 times
- arnocill
- What model do you have?: beamish buggy
- Has thanked: 6 times
- Been thanked: 4 times
This buggy was sold less than a month ago! Probably for far less than what this guy wants for the motor.
http://www.aircooledvwsa.co.za/viewtopi ... =3&t=28929
- eahmod
- What model do you have?: 1973
- Has thanked: 33 times
- Been thanked: 7 times
Got a strong feeling the engine is from the Black 2ltr Buggy being sold sometime back.
http://www.aircooledvwsa.co.za/viewtopi ... 27#p271327
If this is the case, the engine sole purpose was for drag racing, those eliminator heads are not meant for street use and will proberbly overheat.
My 2c worth
My 2c worth
thats all wonderful and all, but those are not eliminator heads.
You can see by the fins around the mounting bolts that they are stock style heads, not eliminators.
Other than that, I dont want to share my thoughts on buying this engine
- riaanj
- Been thanked: 41 times
This oke only posted here like he did on gumtree, it's an add only, he'll probably never answer any questions..
@Eben , can't we make it that you can only post in the for sale or wanted areas once you are over a certain amount of posts?
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
Who hooks up the accel. cable the way this one has been done? LOL. I guess detail on this build is not one of the strong points.
