Can I retrofit door handles?
Merlin
Has thanked: 20 times
Been thanked: 39 times
Post by Merlin »
's up?
Up 'til '66 bugs had the 'pull'-type straight interior handles...'67 went recessed horizontal handles.
Fitting earlier handles...is is straightforward?
Thanks, N.
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Can be done with some surgery and modification but is not a straight swop.
A
vader
Post by vader »
Sorry MTM I don't quite follow what your saying. Explain a bit more please?
Merlin
Post by Merlin »
Thanks IMPI.
We'll chat a bit more about it over the phone later this year. ;)
Vader...
Up to '66, bugs had, like buses, small levers which you pulled towards the back of the car to open the door.
'67 onwards had more 'modern' handles, which sit in a recess, and you pull towards yourself?
Make sense? :s
N.
vader
Post by vader »
Is that on the outside or the inside? The DarkSide is a '66 but has two different types of handles on each door (outside)
Maybe Hitler can take some pic of us and you can have a look..
But if I think about it would it not be easier to just swop the doors?
Merlin
Post by Merlin »
Inside Vader.
I'm a little sketchy, but I think '67 doors were a little different?
Your '66 should have the old-type interior handles then, that I'm after.
I want to conver the handles, winders, and dash knobs all to pre-67 style.
vader
Post by vader »
I must say I really like my handles and window winders they are much better and it's a good idea if you can change them.
get Hitler to take some pic's of the DarkSide's doors as the panels have been removed and you will be able to see what needs to be changed... If the '66 doors fit it might be a straight swoop...
These are the outside handles of the dark side. Vader how the hell do you open the doors to get in. Which key fits where?
Merlin
Post by Merlin »
Nah, I'm talking about the interior handles.
'66/'67 has the handles on the left. '65 and earlier, the right.
Only the driver's door can be operated with a key.
Merlin,I understood you when you wanted inside handles but as I asked Vader - I need to know which key on his bunch actually opens the door so as to get in and take a pic of the inner handles.
vader
Post by vader »
Use the key that has the oval end and notches on the one side only. Or slide a sharp knife under lock in the 3/4 vent and flip it open then you can just stick your hand in and open the door... Opening the door is th easy part it's when you try to close it thats when the frustration happens. The door keeps popping open.....The locking alignment is a bit iffy!!
He obviously hasn't broken into a Beetle before.
vader
Post by vader »
No he's got a BBuggy
They are a bitch to open!
vader
Post by vader »
HAHAHAHAHAHA
