Weber Twin Carb 36 "B-Gas", Custom SP Inlet.
Get your parts here
Darth
What model do you have?: One with wheels
Post by Darth »
Weber 36 Twin Choke Progressive Carb "B-Gas" jetted for a 1971cc Sp making 155Nm & 55Kw @ 5500rpm, fitted to a custom Single Port Inlet Manifold with heat exchange tubes.
R1 800.00 :drunks: ONCO
Do! Or Do Not! There is no Try! - Yoda
If I haven't offended you today yet, then wait you fcken turn I'm still getting to you.
Wake up each day to be a better you. Unless you are a DOOSE Don't be a better doose!
Darth
Re: Weber Twin Carb 36 "B-Gas", Custom SP Inlet.
Post by Darth »
If you do off road driving (dunes, ruff terrain, baja bug) a single carb setup is better than twin carbs due to floatchamber sloshing. This Weber carb and intake setup effectively allows you to have a twin carb setup without the hassle of linkages, sloshing & ballancing twin carbs. Plug and play..
