New & used bus & beetle engine parts (part 1)
Get your parts here
Been thanked: 98 times
Portugal
Post by calooker »
I got hold of a huge stash of mostly engine parts new & used, the used items are all in usable condition, heads have no cracks, most engine blocks are good as is, used parts need cleaning as they sat for many years.
These are bulky items so collection is preferred, priced to go or well below current new prices.
If you need pics or info I can send via whatsapp, send me a message.
Motors have been bench tested, good to go.
Used parts
T4 1800 / 2000 heads with valves used 39x33 R750 each
T4 1800 / 2000 heads no valves used R450 each
T4 1800 / 2000 heads with valves 39x33 reconditioned R1500 each
T4 2000 engine block std R750
T4 1800 engine block std R750
T4 1700 sub assembly R1000
T4 1800 215mm flywheel & pressure plate, FW needs re-facing R300
T4 103mm big bore kit, sleeves & pistons only R1000
T3 1500 engine block 1mm cut R500
T2 1600 engine block std R750
T1 1600 engine block 1mm cut R500
T1 1600 engine block 1mm cut fresh line bore R1250
T1 1600 Complete rebuilt engine, bench run, with genny & 36HP fan housing, needs carb & exhaust R5500
T1 1966cc 76x90.5 with Engle 120 cam, 40x35.5 pored heads, 4-1 exhaust, 36Hp fan housing, many other go fast bits, done less than 2000km only needs a set of carbs to run R32500
T1 1600 twin port heads rebuilt R1250 each
T1 1600 single port heads with valves R350 each
T1 Empi twin HPMX 44 carb kit with manifolds & rebuild kits R4000
T1 12v Generator with fan R250
T1 12V Alternator needs regulator R200
T1 92mm big bore kit with new rings R3000
New parts still in boxes
T4 94mm sleeve kit, new rings & pistons used sleeves R3500
T4 96mm Keith Black sleeve kit R8000
T4 228mm clutch plate R150
WBX 2.1 NOS 94mm rings R300
T1 CB Performance 044 Wedge port heads (hand ported) 42x37 valves R11000 set
T1 CB Performance 044 heads 42x37 valves R8000 set
T1 Empi twin HPMX 44 carb kit (complete all linkage manifolds etc.) R9500
T1 Mahle 94mm forged piston & sleeve kit for stroker crank R6500
T1 EFI twin inlet manifolds with mounting hardware R1250
Transmissions with side shafts & drums, will need axle boots & fresh oil
T3 1500/1600 with longer 0.89 4th bell housing a little damaged due to FW coming loose, but good to go. R1000
T1 1200 R750 with throw in a extra box with no side shafts.
T1 1300/1500 R750
I can hook up motors to a bench & you can see them run.
Prices are rock bottom, no negotiations, the new items are between 30-50% less than current cost.
Rui 082 830 6493, I'm in JHB
Re: New & used bus & beetle engine parts (part 1)
you have pm
Edmond
Has thanked: 22 times
Post by Edmond »
Pm sent
