75 Baywindow Project
sean
Has thanked: 63 times
Been thanked: 227 times
Post by sean »
75 Baywindow Project. Started more than a year ago now.
This one came from a settlement just behind Barrydale. Body was very solid, had a few rusty spots under the windscreen, side windows and behind the rear bumper. There were quite a few dents and quite some major damage to the bottom of the sliding door as the rollers were broken and it obviously fell off many times.
Engine was not so good though. Firstly it was a microbus 2.0L with all it's tin cut up to fit baywindow engine bay. Carbs, links the lot were absolutely trashed, everything was bent and damaged. The motor itself is also rubbish. Fins are broken off, dropped valve seats, crank play and not even heads that match. One is a CU and the other a CJ head. Not to phased as it was the body that is worth while.
Here are some pics of picking it up. Will post progress pictures a bit later. It is almost finished.
487
488
489
490
493
492
491
lowlight
Re: 75 Baywindow Project
Post by lowlight »
Nice bus. body looks OK
VW1600S
What model do you have?: 69-1500/72-1600/
Post by VW1600S »
Checks lekker, seems to have minor rust. Mine was worst! Good luck with the project.
RICKY-R69
What model do you have?: 76 kombi,1970 beetle
Post by RICKY-R69 »
Looks good. My bay was a worse sight for sore eyes. See the did the same as on my bus. Attached the gooseneck for towing directly onto the rear bumper!
sean
Post by sean »
Pics during restoration.
551
552
544
545
sean
Post by sean »
Pics after spraying the body
547
548
549
Looks good!
Like the fact that you echoed the original colours, :hangloose:
Looking great Sean :hangloose:
sean
Post by sean »
Well, I see as per my first post, it has been exactly 5 years since I started this thread and the bus is now finally complete. I took it for its first drive this week.
I changed colour in the end. Decided to get this one done and go with a different colour to what it was.
The colour is Aqua Marine, probably one of my most favourite colours offered for a bus.
I did the spray job about 2 months ago which came out really nice and just spent the last while installing the drive train, exterior fittings etc.
Here are the pics.
Some pics when doing the re-spray.
sean
Post by sean »
Here are some final pics I took yesterday.
The engine is a 2.0L type 4 which has been rebuild, but back in 1998 by Andreno motors. I just replaced the oil seals, but otherwise the motor is still going great. I had this motor waiting to be used in a bus again. I have managed to balance and set the carbs pretty close, but still got a little bit of fiddling to get them 100%.
sean
Post by sean »
I was a little indecisive with the interior, but decided in the end to go with white. The creams and brown would not have gone well with the outside colour......
Chardivw
Oil Seal
What model do you have?: 78 kombi 2000l
Facebook: Snowater photography
Has thanked: 12 times
Been thanked: 15 times
Post by Chardivw »
Very awesome! Congrats
Very ..Very....Very ...NICE.
fourier
Has thanked: 31 times
Been thanked: 37 times
Post by fourier »
Wow, awesome looking bus Sean. Good job!
(o= i =o) (o\ ! /o)
lovely!!
