It's a Sand Rail?????? My new toy
- Has thanked: 78 times
- Been thanked: 37 times
Re: It's a Sand Rail?????? My new toy
Thanks Terry much appreciated.
Saves me from having to pinch the set from the Spyder.
- John Alves
- Has thanked: 3 times
- Been thanked: 48 times
I agree, otherwise it can sit for another 10 yearsPine wrote:Just a suggestion - fix it 'on the go'. Do one thing at a time - remove, repair/replace, re-install - drive!
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
1968 1500 SP Beetle
Thanks to Terry (gave me a peddle assembly) I can now carry on with the clean-up of the Rail
- Has thanked: 193 times
- Been thanked: 121 times
This weekend I decided to play around with colour
combinations and the above is what I have narrow ed it down to. Although I quite like the grey.
Nice and I quite like the colour
Anyone know where I can get hold of a NON working machine gun that I can mount on top of the bars of the Rail?.
I don't think that is such a good idea in this trigger-happy country of ours...64 Notchback wrote: ↑Fri Mar 03, 2017 12:02 pmAnyone know where I can get hold of a NON working machine gun that I can mount on top of the bars of the Rail?.
There are strict laws against the public display of weapons in SA, even if they are non-working or replicas. Search for 'Mike's Models' on FB - Mike makes resin replicas of all types of weapons, you can also contact him at 072 222 6789 or look at his web site www.sadfi.org/. He should give you the correct information.
Over the past month I have been cleaning out my garage and general cleanup around the house and found some stuff to cote the rail. It is called Belzona we sell it at work. This particular product is used to create a non slip area but I did not use the grit.
I decided to cote the inside of the rail with it, only thing is you only have about an hour to work with the stuff as you mix it with a solidifier. It think it will also help protect from rust
- What model do you have?: type 3, Porsche 550
- Been thanked: 15 times
64 Notchback wrote: ↑Fri Mar 03, 2017 12:02 pm Nice and I quite like the colour
