SC Fleetline Splitty
Re: SC Fleetline Splitty
Thanks Jolas
As you can see I had a real Hard time to choose a Color
For A client it is much easier as they want the normal Average nice
But for your self you always want to be or try and be one step ahead with choosing a color
And I think the Ghia and SC will look good Next to one another
So Assembling Started
But Front and Back Suspension was first removed
And cleaned
Also Pressure cleaned Chassis
And Masked the Bus to Stone Chip under belly
Even has to cling wrap my hoist in the Man cave as I did not wanted it full of Stone chip
Put a Cote of paint on the front Disc brake kit
Front Suspension both adjusters installed and fitted a new Pitman Arm steering pin kit
Parked for the Night
In the Morning wil paint 2k black paint mixed with 2K clear to seal the Stone chip and finish it off smooth for easy clean
Some update pics
Finished this bus in record time to take it to 2017 NASREC Exhibition
Long 3.88 diff ratio and Long 4th gear ratio with RGB transmission for good Highway croozing built
Interrior combination
On the way to the show
My Ghia where I choose color from
hendriks
Been thanked: 13 times
Post by hendriks »
Baie nice Pierre!!!
Thanks Hendriks
