Build projects by Vdubtech
I will Post pics of different Projects Vdubtech builds in this thread
Splitties,Bay,Beetle and more
Hope you guys enjoy
We also do Inhouse Upholstery
My bus Going to 2017 NASREC and people can buy a block paint on for Charity
A Pizza Trailer busy with
Splity of Duane we building
Front Suspension adjusters fitted and back lowered
Some work done on this beauty
Roof lining and Engine refresh
Another Splity after sandblasting
Needs a lot of metal replacement Image
1958 nose replaced and most metal work done
Re: Build projects by Vdubtech
Black Speedster 911 motor and Extra long ratio Bugger Stg 1 box
Gold one Subaru turbo motor
A Highlite fitted with Lowlight bumpers
Back is Fiberglass we supply
autobus
What model do you have?: kombi 1972
Facebook: https://www.facebook.com/Jeroen.van.Rootselaar
Post by autobus »
Hi there, are you selling these fibreglass bumpers? I'm searching for those...
HI
Which Bumpers the Bus ones then Yes
0826008663
Masking and chassis black
splitbusahollic
Facebook: vintage kombi
Has thanked: 87 times
Post by splitbusahollic »
what type of welding do you guys use on these projects Pierre ??
vintage kombi.co.za (Website)
vintage kombi on Facebook
YvaneS
What model do you have?: :)
Has thanked: 11 times
Post by YvaneS »
Love that Oval! Looks great! :hangloose:
Pierre, what are the specs on the Oval's engine?
YvaneS wrote: Fri Aug 04, 2017 3:34 pm Love that Oval! Looks great! :hangloose:
Engine is around 2180 CC
Dave Rowley buit it originally we just Replaced Rings and B/e bearings and sorted some other minour Issues
Pics of Vdubtech built
Eugene
Has thanked: 59 times
Been thanked: 65 times
Post by Eugene »
splitbusahollic wrote: Wed Aug 02, 2017 8:54 pm what type of welding do you guys use on these projects Pierre ??
50 bucks say it's metal welding :twisted:
I bought this limo about 2 years ago
It was owned by about 4 or more owners before and seem every one just put more polly on the previous
It also had a Rover V8 motor in
That I removed and installed a 2L Gold GTI motor
Sourced a Rack and pinion Power steering system with lots and lots of headaches I managed to get it to work
Now it is time to get Body work sorted
Started removing All paint
There are amazingly amounts of Body puty on this body
I have used 3 of the Special discs that Sean is using on his projects
Now busy with flapper sanding disc to remove paint and 10tonnes of body putty
It seems most is pop riveted together
So there is a much bigger task awaiting us once all paint is removed
1 Advantage is that it seems that who ever did the Chassis did not do a bad job there
But I will still be Adding a few additional supports
Also sourced a set of High jacker air shocks for additional rear supports
Wish us lock ImageImageImageImageImageImageImageImageImageImageImage
Been thanked: 539 times
Thats going to be a nice one
Will be waiting for progress post on this one for sure.
Please keep them coming.
AlanH
Has thanked: 117 times
Been thanked: 86 times
Germany
Post by AlanH »
Nice, I'm also busy with that paint removing including body putty. They do look good cleaned up though.
Good Luck, will be monitoring progress and looking forward to more pictures.
Wanted parts:
Left sunvisor
Sink faucet
I do have a 15Window Split bus rear clip with the Corner windows that we will be fitting on the rear
As I do not like the rear look of the Brazilian
I also have left and right rear wheel arches available
While removing the paint you can see the thick piece of body putty that some fool have mixed with Cardboard to close a round hole on the nose
That we have already closed the right way by welding it closed with a patch
The next boomerang looking piece of body puty comes off the lhs rear wheel arch
This again is the reason why I am removing all paint to start fresh
On the1 pic you can see how thick the Body puty is and the hole where a door handel was is closed with a piece of metal and pop riveted
